BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > Gen1 G-series CustomROM Support - Now Available!
Studio RSR
      06-29-2022, 09:50 AM   #1
proTUNING Freaks
proTUNING Freaks's Avatar
4496
Drives: powered by bootmod3
Hey gents,
Gen1 G-series B58 CustomROM support is now out! All the features have been incorporated that are supported across other vehicle models/engine types. Lets see these cars moving!
      07-13-2022, 07:21 AM   #2
Mikej0h
Netherlands
49
Drives: BMW 540i G30 2018
Great!
Just one question regarding the flex fuel. Is this a requirement to run multimap or is it recommended?
      07-13-2022, 11:03 AM   #3
abbike18
Drives: 2019 BMW X3 M40i
Originally Posted by Mikej0h View Post
Great!
Not from PTF, but I've been researching this a bit so I'll chime to to see if I can help.
Not required - it is a feature of multi maps. If you don't have a flex fuel sensor installed, multi maps works by running the car in whatever tune you have selected. Multimaps allows you to switch tunes quickly based on different fueling.
Without a flex fuel sensor multimaps also offers all the other benefits like antilag, etc.
If BM3 sees a flex fuel sensor on your system, then it will automatically adjust the current tune to the sensed ethanol value, with the most conservative tune being the currently selected tune. So you want to run your car in the map of the minimum fueling you expect the car to see. For example, if you live on a place that has quality 91 (not ACN) as the pump gas fuel, you would run your car all the time in a Multimap set (stage 1 or 2) with the 91 octane map selected. If BM3 senses 10% or less ethanol, it will run the base 91 tune. If it senses greater than 10% ethanol (ie, you fill up with some e85 to 30%), it will blend in higher torque, ignition and fuel volume targets automatically. In this case it would create targets similar to the E30 map. But the beauty of flex fuel is if you fill up to E25 because that particular Ethanol pump was a bit lower than e85, it will automatically adjust the map to be slightly less than the E30 map.
2019 X3 M40i | TU Pump | AA DP | VTT GC | xHP Stage 2 | Dorch ECA | MHD Odin FF | Carbon Black | Adaptive Suspension | M-Sport Rear Diff | 20" staggered
SOLD! 2015 X1 35i | Alpina Trans Tune | Dinan Stage 2 | Bilstein B6
Mikej0h48.50
      07-13-2022, 11:10 AM   #4
mike@x-ph.com
mike@x-ph.com's Avatar
Drives: 07-335/12-328/18-M4/21-M4CP
Nice
https://x-ph.com/sale/
Phone number 702-494-9435
antilag, bm3, bootmod3, customrom, e85, flex fuel, map switching
