07-08-2022, 05:15 PM | #1 |
Rep 459
Replacing rear dif. transfer case - concern
Hi everyone.
Recently, I started hearing kinda thumping noise coming from the rear. Took car to the mechanic and he diagnosed that sound is coming from the rear differential transfer case. Topped of dif oil (it was a small leak) but noise didn't go away, so we decided to find an used part. My mechanic got one from tx that belonged to 340i (mine is 2013 335i). What concerned me is actual writing on the part where it seems to say 328i (or it could mean something different). In the case that part is really from 340i, Does anyone know is there any difference between 335i and 340i part? Part numbers for both can help greatly. I accume installing one from 328i would be bad idea. Thank you! |
07-09-2022, 12:10 AM | #3 | |
Rep 1,117
Although the final ratio is the same as yours at 3.15, you never state if your 335i is an X-Drive or not. Regardless, the output shafts are different and I suspect will not fit with yours. I also have some doubts about the connection to the driveshaft. Now if you really wanted to do it right, I’d put in a BMW MPerformance LSD. I know where a new one is, but it isn’t cheap. https://www.ebay.com/itm/30423572138...p2047675.l2557 Last edited by YASBBYM3; 07-09-2022 at 12:41 AM.. |
07-09-2022, 01:11 AM | #4 | |
Rep 708
How the hell do you know the exact vin of the part?
Just from the barcode? That’s the only info i can see from the pic. Quote:
YASBBYM3592.50 |
07-09-2022, 09:58 AM | #5 |
Rep 787
If your rwd, I have a part that you can use. I swapped the stock rear diff off of my 335i with only 21000 miles on it. It's been sitting in my garage ever since. I'd let it go pretty cheap if you're interested. As others have said, rwd vs xDrive and 335 vs 340 there will be differences as well as automatic vs manual transmission. You've got to ge the right one for your car
335i rwd auto, 2015 with m performance LSD and Dinan stage 2. Cts charge pipe, mad 5" stepped intercooler.
90rr106.50 |
07-09-2022, 02:17 PM | #6 |
Monobloc
332
Rep 449
Drives: '02 M Coupe - '19 F31 330ix
The VIN is posted in the Ebay link, in the description section.
-2023 Honda Odyssey Elite - Sonic Gray Pearl / Black
-2019 F31 330ix Individual - Champagne Quartz / Coral Red (M-sport, Exec, Premium, Track) -2004 Honda CRV AWD - Silver / Black -2002 S54 M Coupé - Steel Gray / Dark Gray/Black |
07-09-2022, 07:21 PM | #7 | ||
Rep 459
07-09-2022, 07:22 PM | #8 | |
Rep 459
07-09-2022, 09:57 PM | #9 | |
Rep 708
07-10-2022, 10:22 AM | #10 |
Rep 787
I was lucky enough to grab one of the m performance LSD when they went on clearance a couple of years ago. It was a great deal for about 2 weeks until they sold out and production ceased after that. Aftermarket is the only option now.
07-10-2022, 02:10 PM | #12 | |
Rep 787
"If your car has a 3.15 final drive ratio, it will work, 328 or 335, AWD or RWD Realoem does not list the LSD as working with the 328, but the original differential is the same part in the 335 and the 328 for the 3.15 final, which is the key. " This is only for pre-lci automatic transmission as well. Lci (2016-onward) cars got a new final drive so they would have a different part. I don't know much about that since I have a 2015. If bmw does make one, it's going to be around 2500 + install. That's where the part for the 335 was priced before closeout.
90rr106.50 |
07-10-2022, 07:42 PM | #14 |
Rep 787
Improved traction. Best during cornering but also felt during straight line acceleration and braking. Enables the car to take advantage of all the horsepower without wheelspin.
07-10-2022, 08:50 PM | #15 | |
Rep 666
if it fits 328i, does it mean it fits the 320i as well since 320i and 328i shares the same N20 engine (and I think same ZF8 transmission as well)?
07-11-2022, 01:11 AM | #16 | |
Rep 1,117
90rr106.50 |
07-11-2022, 01:13 AM | #17 |
Rep 1,117
As i stated above, I know where a new unused OEM BMW MPerformance LSD is available, so aftermarket is not the only option now.
07-11-2022, 01:52 AM | #18 |
Rep 1,117
07-11-2022, 08:46 AM | #19 | |
Rep 787
I wouldn't think it would be worth the money and effort to the guy asking about the 320i. Those cars aren't making much power and typically shouldn't be breaking grip on a stock setup. If you aren't running extensive engine mods on a 320, the lsd is probably not worth the investment.
07-12-2022, 10:22 PM | #20 | |
Rep 1,117
Bottom line, the fact that the OP diff were not comparable should have given away that statement was also in correct. |
07-13-2022, 05:02 AM | #21 |
Rep 1
architecturesstyle
If you are fascinated by architectural design styles, then this is the right place for you. The best way to make your home more lively is with our cutting edge design concepts related to architecture, decoration, and interior design. We have the prowess to provide you with contemporary ideas for both residential and commercial properties to brighten up your space and give a new dimension to your architectural style regardless of where you live.
https://architecturesstyle.com/ |
07-13-2022, 07:09 AM | #22 | |
Rep 422
