BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N47 and N57 Turbodiesel Engine / Drivetrain / Exhaust Modifications > Guess I need a fuel injector
      07-29-2024, 05:47 PM   #1
cezar22
Drives: 2016 328dX
This is on my USA 328d.
Getting a code for fuel injector: P02D1
Sounds like it's partially clogged and the ECU has determined it can't make any further fuel trim adjustments.
What is the accepted process for this? Order a new one? Order four? Send mine off to be cleaned and flow-tested?
Is the process for swapping them easy? I'm guessing crack the fuel rail open a smidge somewhere to bleed off pressure and then unbolt, pull out, and replace?
      07-29-2024, 05:49 PM   #2
cezar22
Drives: 2016 328dX
Oh my god they are $550 a piece???!?!?
      07-30-2024, 01:02 PM   #3
FaRKle!
Get a used one from eBay (search the listings from Europe).
-My YouTube Channel for some of the best DIYs and in depth information
Please don't PM me for suspension recommendations unless interested in paid private consultations.
      07-30-2024, 03:50 PM   #4
barf
Drives: F30 330D
Very easy to replace on these engines compared to older M57.
Just get a used injector and code IMA values with ISTA or other tool when you have the time.
Coding IMA value is not that important but helps to keep the adjustment values down.
      08-01-2024, 02:41 PM   #5
328dabi
328dabi's Avatar
Drives: 328d
Ultrasonic fuel injector cleaner is one of the best investments.
      08-04-2024, 09:04 PM   #6
n00bkiller944
Drives: '14 328d M Sport
Cheaper than a new injector too
328dabi170.50
      08-15-2024, 08:03 AM   #7
cezar22
Drives: 2016 328dX
UPDATE UPDATE UPDATE
I bought a bottle of Archoil diesel additive and dumped the entire bottle in while filling up. The car runs quite a bit smoother now and the CEL is gone.
      08-17-2024, 11:56 PM   #8
FaRKle!
Lucky! Now make sure to use something like hot shots EDT every fill up, and their diesel extreme twice a year to keep the injectors clean.
