BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Diff oil question
      04-18-2021, 01:10 PM   #1
negendahl
negendahl's Avatar
Denmark
Drives: 2015, F31 320D
Diff oil question
Hi,
I want to change the rear diff oil in my 2015 F31, found the original oil (83222295532) on realoem, it costs a fortune (or, around 100EUR for 1.5 liters) 😅
Would Castrol Syntrax Longlife 75W-90 be alright for the rear diff? Its around 30EUR for 2 liters, so quite a different price.
Thanks!
      04-18-2021, 03:23 PM   #2
jbiswurm
Drives: F30 335i msport 6mt
Originally Posted by negendahl View Post
Hi,
Thanks!
Any high quality 75w-90 or 75w-110 will be fine. Just plain old gears back there that need plain old gear oil.
      04-18-2021, 03:26 PM   #3
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
The BMW fluid is 75W-85, so that's close enough. To be sure if it's OK you need to find the API rating on the BMW fluid and see if the Castrol equals or exceeds it.
      04-18-2021, 04:24 PM   #4
frchdragon
frchdragon's Avatar
345
Drives: 2016 BMW M4
2003-present xDrive Models (ATC Transfer Case)
BMW recommendation: DTF-1 (previously TF0870) 75W GL-4
All Front Differential
BMW recommendation: SAF-XO, 75W90 weight, GL-5 rated
Our recommendation: Red Line 75W90 - LIQUI MOLY LM2048 75W-90 Gear Oil
Rear Open Differential, after 7/2011 production*
BMW recommendation: G1 synthetic, 75W85 weight, GL-4 rated
Our recommendation*: BMW G1 if under warranty, Red Line 75W85 GL-5 (Red Line-approved) - LIQUI MOLY LM2048 75W-90 Gear Oil
I put Liqui moly in both front and read diff. I would stick to a GL-5 75W85 or 90 gear oil.
Rear diff had no drain plug you need to bend a tube and suck the oil out. And you are supposed to replace the plug with a new one... What a waste.
'16 M4 bone stock
'13 335ix Msport BM3 stage1 - MAD FMI - FTP CP - Bilstein B4 (SOLD)
'85 635csi M30 turbo race car (SOLD)
      04-18-2021, 09:02 PM   #5
johnung
johnung's Avatar
Hi,
Thanks!
I'm a big believer in using BMW fluids or fluids from manufacturers who make them for BMW like ZF transmission fluid or Shell Austria Transfer Case fluid (both available from FCP Euro). I don't believe there is an upside to believing marketing claims from fluid manufacturers.
FYI- the Bentley manual says that BMW recommends only using rear differential fluid with SAF-XO designation. If you use another fluid then check for that.
It's usually a suction through the fill hole procedure. Tightening torque on plug is 60 Nm (44ft-lb)
Note: it's interesting that according to realoem, the stock rear differential for my 2015 335ix automatic takes 1.5 liters of BMW fluid part number 83222295532. The Bentley manual doesn't list a rear differential fluid capacity (but is says the front differential takes 600ml)
But I know that my rear M Performance Limited Slip Differential only takes 1 liter of BMW differential fluid part number 83222357992. So the extra LSD components must take up about a half liter of physical space, assuming the housing capacities are the same.
Hope this helps!
      04-18-2021, 10:44 PM   #6
frchdragon
frchdragon's Avatar
345
Drives: 2016 BMW M4
Redline and Liqui Moly are some pretty pretty decent fluid manufacturers...
I saved many older manual transmissions using Redline MTL where BMW fluid would have doomed them.
I ran non BMW fluid in many BMWs well passed 200k miles. My BMW race car is seeing a huge amount of abuse on non BMW fluid also.
I don't buy my parts at the dealer, I sure won't buy my gear fluid and engine oil from them either, but I understand if people think that the dealer knows best.
'16 M4 bone stock
      04-19-2021, 01:57 AM   #7
negendahl
negendahl's Avatar
Denmark
Thanks!
Redline is hard to get around my parts, but i can get my hand on some Liqui Moly oil - that would then be this one, correct?
https://products.liqui-moly.com/oils...-75w-90-1.html
Thanks!
      04-19-2021, 01:59 AM   #8
negendahl
negendahl's Avatar
Denmark
Thanks! I totally get the idea of using only the OEM product, just seems like quite a price difference - not totally convinced that it's a better product than whatever else is available.
But I appreciate your input, thanks!
Hope this helps!
johnung5094.00
      04-19-2021, 04:59 AM   #9
johnung
johnung's Avatar
I didn't say that the "dealer knows best". Dealers mostly parrot BMW's Lifetime Fluid claims, something designed to get BMW to the end of their legal liability. BMW Corporate bean counters could care less if our cars last past the warranty. They are in the business to sell us new cars.
I rarely buy anything from a dealer. But I do buy genuine BMW parts when necessary at a discount from retailers like FCP Euro.
I'm more concerned that I use the fluid that the engineers who designed the component specified. That's why I use ZF fluid in my ZF designed and manufactured transmission.
Sure people use aftermarket fluids with no problem. But there are also horror stories about aftermarket fluids having negative results. IMO I don't see any upside to risking a really expensive transmission, differential, Limited Slip Differential or Transfer Case based on aftermarket fluid marketing claims, or trying to save what is a negligible amount of money compared to the replacement cost of the component that it's protecting.
      04-19-2021, 05:06 AM   #10
negendahl
negendahl's Avatar
Denmark
Yeah, youre right - its not worth risking the diff og transmission ect. (im getting a transmission oil flush tomorrow at the BMW service (dealer), they will use OEM)
      04-19-2021, 05:33 AM   #11
negendahl
negendahl's Avatar
Denmark
Just ordered OEM oil (83222295532) + plug (33117525064) - thanks for the help guys!
      04-19-2021, 10:49 AM   #12
johnung
johnung's Avatar
Do you mean transmission? I thought you were discussing your rear differential fluid? That's a simple suction through the filler hole and refill.
You would probably get a much lower price through a local BMW independent mechanic.
The automatic transmission service is a special procedure with a complete replacement of fluid, pan with its built-in filter, and pan bolts. The ZF Service Kit costs under $300. Genuine BMW kit might be 2x that.
      04-20-2021, 05:29 PM   #13
Orion4
Drives: 2013 335i Sport Line Sedan
Unless you perform a Transmission "Flush" with special equipment you are only removing/replacing about 2/3 of the full capacity. The local dealer and my Independent BMW Master Mech. both Do Not recommend the flush. Potential for damage apparently is significant. At FCP, a BMW Automatic service kit with ZF fluid is $303 and one using Liqui-Moly equivalent is $186
      04-20-2021, 09:27 PM   #14
johnung
johnung's Avatar
Seven liters of transmission fluid comes with the ZF Kit. My automatic transmission service followed the recommended procedure and took almost six liters.
      07-13-2021, 05:42 PM   #15
T-Bone18
Drives: 2014 535i xDrive
Which fluid do you recommend for a rear differential BMW 2014 535xi ?
I phone redline and they saying 75w90...
      07-13-2021, 06:44 PM   #16
sspade
sspade's Avatar
2016 BMW 320i  [7.87]
2014 BMW 328i  [6.83]
Originally Posted by t-bone18 View Post
which fluid do you recommend for a rear differential bmw 2014 535xi ?
bmw oem pn: 83222295532
      07-14-2021, 07:47 AM   #17
frchdragon
frchdragon's Avatar
345
Drives: 2016 BMW M4
75w90 is good. You can't go wrong with Redline or Liquimoly oil. Or BMW oil if you only believe in dealers.
'16 M4 bone stock
      07-25-2021, 01:25 AM   #18
breakitout
Drives: 328i M Sport
I have been running Castrol Syntrax Longlife 75W-90 for my last two diff oil changes and have had no issues for what it's worth.
      08-04-2021, 12:28 PM   #19
123Britt
Drives: 15 M235i AT; 2008 Z4 3.0Si MT
States 3 x .5L G1
I could only get in 2 X .5L
Good thing because I only ordered (2) .5 Bottles
sspade2527.00
      08-04-2021, 01:52 PM   #20
sspade
sspade's Avatar
Sounds right, should be 1 litre total. IDK why the chart above shows 3 x .5 = 1.5L
      08-20-2024, 11:10 AM   #21
drunlock
Drives: bmw 335d 2017 f31
edited diff oils liqimoly
is the oil same for front diff and rear diff if using LIQUI MOLY Fully Synthetic Gear Oil (GL5) SAE 75W-90
