09-14-2024, 10:28 AM | #1 |
Rep 109
Fuel filter replacement?
Searched and surprisingly there is nothing on this. I'm doing my fuel filter tomorrow and I have a few questions:
- Online posts seem to imply you can disconnect/reconnect the green clip side of the lines without removing the clips. Is that true and what is the procedure? - Online posts also seem to imply that if you remove the heater/exit side first it prevents fuel from draining back. True or false? - I have a foxwell scanner with BMW support. Is this adequate? Again, online posts seem to imply that ISTA does a multi-step procedure that the foxwell cannot do - Or can you just turn the car on and off a bunch of times (not starting, just on ACC) to prime the filter? BTW the Bentley manual says to undo the heater/exit side first, then "undo" the other side, and that's IT. So why am I seeing so much doom and gloom online about the "right" way to do this? What is the right way to do this job? I'm seeing lots of things making me superstitious that I'm going to blow up my HPFP if I do the procedure wrong and it's got me nervous. |
09-14-2024, 01:26 PM | #2 | |
Rep 5,854
09-14-2024, 06:59 PM | #3 | |
Rep 153
09-20-2024, 10:15 AM | #4 | |
Rep 443
09-21-2024, 10:44 AM | #5 |
Rep 914
Adding to this, prime the pump multiple times (at least 3). The last time I changed my filter, I ran a single prime ABL in ISTA and there was still air in the line. That first long crank was the stuff of nightmares.
2020 i3 Rex: Capparis White, Giga World |
