04-05-2023, 01:30 PM | #134 |
Rep 23,212
getBMWparts.com | Genuine BMW M Performance Brake Kits!!! Brembo high-performance 4-piston aluminum fixed caliper on the front axle and 2-piston aluminum fixed caliper on the rear axle. Available in M Performance Red, Yellow or Orange all with an M logo on the outside of the caliper. Improved thermal resistance thanks to larger, internally-vented lightweight construction sports brake discs. Cross-drilled and grooved brake discs also reduce water film build-up between the brake lining and the disc surface. Drilled and grooved, internally-vented lightweight brake discs with riveted aluminum hat measuring 370 x 30 mm (diameter x thickness) on the front axle and 345 x 24 mm on the rear axle. (rear brake discs sold separately) Shop & Save on M Performance Brakes Here!!!
Evan Winstead · Internet Parts Director
Contact Us | Facebook | Twitter | New: Shop Porsche & Audi parts! |
09-17-2024, 10:48 AM | #137 |
Rep 23,212
getBMWparts.com | Genuine BMW M Performance Big Brake Kits!!!
Brembo high-performance 4-piston aluminum fixed caliper on the front axle and 2-piston aluminum fixed caliper on the rear axle. Available in M Performance Red, Yellow or Orange all with an M logo on the outside of the caliper. Improved thermal resistance thanks to larger, internally-vented lightweight construction sports brake discs. Cross-drilled and grooved brake discs also reduce water film build-up between the brake lining and the disc surface. Drilled and grooved, internally-vented lightweight brake discs with riveted aluminum hat measuring 370 x 30 mm (diameter x thickness) on the front axle and 345 x 24 mm on the rear axle. (rear brake discs sold separately) Red: 34-11-2-450-468 Yellow: 34-11-2-450-469 Orange: 34-11-2-450-470 On special in our M Performance Catalog Here!!!
Tags |
bbk, getbmwparts.com, m performance, performance brake kit, red calipers |
