BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > F31 with 18 x 8.5 square?
      04-18-2020, 11:20 AM   #1
jskibo
Drives: BMW F31
I picked up a 2015 F31 yesterday. Original owner must have had issues parking as the 397s are beat to hell.
The Wagon is kind of an oddball as it has:
Sportline
DHP
M Suspension
M Brakes
Looking for a new set of wheels for it and was wondering if I can run 18x8.5 square on it? What ET should an 8.5 be?
      04-18-2020, 11:30 AM   #2
Gen13 F36
Gen13 F36's Avatar
Drives: 428i Gran Coupe
Sportline
DHP
M Suspension
M Brakes
ET32 - 35..... 35 for no hassle fit.
Someone might have there own suggestions... they will just have to speak up.
      04-18-2020, 11:57 AM   #3
alohasurftoad
Drives: 440i gran coupe w/mppsk
DHP M Suspension M Brakes
ET between 30 and 35
for tire sizes
255/40/18, most grip, fills some wheel gap with flushness, i'd do ET35 if 255 due to width.
235/45/18, better ride and impact, fills profile wheel gap some
245/40/18, increases wheel gap, so better if lowered
for a 4cyl with x-drive at stock height i'd use 235/45/18 but other choices are fine also.
      04-18-2020, 07:35 PM   #4
jskibo
Drives: BMW F31
Thank you both!
      04-18-2020, 11:02 PM   #5
FaRKle!
I run a square set of Apex SM-10 18x8.5 ET35 with 245/40r18 tires no problem on my F31.
-My YouTube Channel for some of the best DIYs and in depth information
Please don't PM me for suspension recommendations unless interested in paid private consultations.
      04-20-2020, 03:19 AM   #6
J555
Drives: F31 LCI 340iX
Based on my recent experience, I can only recommend going wider at the front. With significantly more grip, less understeer and improved steering feel, changing the stock 225's for 245's made even bigger difference than I hoped for.
      04-26-2020, 04:12 AM   #7
tl351698
Drives: 2015 YMB F82 & 2015 AW F31
2013 Toyota Tundra  [0.00]
2015 F31  [0.00]
2015 F82  [0.00]
Has anyone run a set of BMW's 437M wheels off an M3/M4?! Or a similar setup? Wheels are 19"x10" and current tires measure 275x35x19 rears and 255x35x19 fronts.
Anyone have any idea if I could run these on my 2015 F31?! Thanks!
      04-26-2020, 06:35 AM   #8
tobefair-idontcare
Drives: BMW 340i
BMW 437M wheels (Black M4 wheels) https://f30.bimmerpost.com/forums/sh....php?t=1020367
17' 340ix|Track Handling Package|MPPSK|MP Stage 2.5 ECU Tune|MP Stage 2 Trans Tune|AP Intake|763M Wheels
      04-26-2020, 12:51 PM   #9
andino
Drives: F31 328i xdrive
I run those on my f31. You can't run that exact tire combo with xdrive. You could run 235/40/19 and 265/35/19 or 245/35 and 285/30 (although you might have rubbing with 285 in the rear without some added camber/lowering)
2016 328ix F31 - SOLD!
2006 997.1 C4S
      04-28-2020, 03:13 AM   #10
tl351698
2015 F31  [0.00]
2015 F82  [0.00]
Thanks Andino- apologies for my ignorance but why does the sidewall height need to be higher in the front than rear? I am fairly certain my existing tires are 225/45/18 all around but I will have to check tomorrow to be sure. I'd be psyched to run the 437s with the tires that are already on them but they are 255/35/19 and 275/35/19 so I might have to pick up a different size..?!
      04-28-2020, 09:07 AM   #11
alohasurftoad
Codestar is running 255-275(2.3%) on his xdrive without issues...https://f30.bimmerpost.com/forums/sh...5&postcount=61. General consensus is having front and rear diameters equal or close as possible is better for the x-drive transfer case, though. So proceed at your own risk!
Another size combo is 255/35/19-265/35/19(1.2%). https://f30.bimmerpost.com/forums/sh...&postcount=265. I think he's selling these wheels with 245/35-285/30 in the classifieds.
      04-28-2020, 11:55 AM   #12
andino
437m are staggered wheels meaning the rear wheel is wider than the front. That's why different size tires are run to optimize the fit. You can run a square tire setup (I run 255/35 all around on my set) but you don't get the ability to rotate your tire without dismounting them.
I would really recommend keeping the difference between front and rear tires as close to 0% as possible. I noticed some hesitation when running 513ms with a staggered tire fitment of 0.4% difference. YMMV but that's why I try to minimal the difference if I can.
2006 997.1 C4S
      05-06-2020, 07:33 PM   #13
LarryO
Drives: BMW 328xi Touring
What about 18x8 square?
Not to hijack the thread, but I have an F31 M Sport with 18x8 square. Any recommendations on doing something wider than the stock 225 tires? I've seen 245/40/18 suggested.
Thanks.
      05-06-2020, 09:08 PM   #14
alohasurftoad
Originally Posted by LarryO View Post
Not to hijack the thread, but I have an F31 M Sport with 18x8 square. Any recommendations on doing something wider than the stock 225 tires? I've seen 245/40/18 suggested. Thanks.
245/40/18 is fine however the since the diameter is smaller, the wheel gap will increase slightly and look more pronounced on an unlowered x-drive. i believe utenigma is rwd so the gap doesn't look too bad. wider shoulders do reduce some gap by being more flush, though. https://f30.bimmerpost.com/forums/sh...MMMM+new+tires
235/45/18 will reduce some wheel gap and is the size i'd recommend on unlowered xdrives. the larger sidewall will provide a better ride and impact protection, trading off just 10mm width compared to a 245/40/18.
https://f30.bimmerpost.com/forums/sh...F45%2F18+dummy
i do not recommend 245/45/18 because wider, heavier and taller(geared) will decrease acceleration, braking, turn-in. large sidewalls makes the wheel look smaller in diameter and look too rally cross'ish
J555571.50
      09-12-2024, 10:27 PM   #15
f31daily
Drives: 2017 f31
I have 18x8.5 35 with 235/45/18. Stock suspension, I noticed a slight speed difference but went away with stage 1.
f31
