BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Wastegate actuator cause drivetrain malfunction
      09-07-2024, 11:47 PM   #1
eduardo_m30
Drives: BMW 328i
Hello Guys,
I’m new at the forum and I wanted to post you some issue I have with a F30.
1. The actuator start failing and was replaced because it cause in the car limp mode also the harness and thermostat were replaced 20 days ago
2. After that the actuator keeps failing after long drives and it causes the propulsion alert and limps again, I park the car after I restart it and the problem goes away.
Also that actuator is doing this haha I don’t know where to search. Did you see any similar problems?
https://youtube.com/shorts/1oE_hLSFY...HGQ-e44bKYq5eL
Thanks a lot
