BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Low fuel pressure codes
      09-13-2024, 09:25 PM   #1
TheSurgical
Drives: 2016 F30 328xi
Over the last 6 months or so I had my 2016 328xi pop a drivetrain malfunction and go into limp mode about 5 or 6 times now. Each time it happened I've been driving for more than 1 or 2 hours (usually 100+ heat), and each time it happened - i would pull over, turn the car off and back on, and it would continue going as if nothing even happened.
I checked the codes a few times and each time it's the same one, P0087 low fuel pressure.
I've had a stage 1 bm3 tune installed for about 2 years/50k miles. I don't drive my car hard, mostly freeway driving with the occasional overtake.
From what I read it could be a faulty sensor in the LPFP and the entire pump needs to be replaced, but from what I've read, the car would just die and not start.
How can i diagnose this or what should be replaced?
Thanks in advance!
