BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N47 and N57 Turbodiesel Engine / Drivetrain / Exhaust Modifications > Fuel level sensor problem after doing hpfp
      09-16-2024, 09:27 AM   #1
MinivanDan
Drives: 2014 BMW 328d
I tried priming after replacing the hpfp and it wouldn't prime due to the tank being empty. The tank had at least 4 gallons in it. I did have a fault for left fuel level sensor and when I ran the test through ista it came back saying the wiring to it was reading -1 ohms. As far as I know ohms shouldn't read negative numbers. I was in the fuel tank at one point and had the low side fuel pump out is it possible the -1 is because I didn't plug it back in? Or is that more a sign of a bad resistor? I did also have the ecu box pulled out for the hpfp replacement.
