01-10-2021, 10:03 AM | #1 |
Rep 10
Coding newbie breaks bluetooth! Help
I'm new to this coding, and done lots of lurking, youtubing, and googling...but I've still managed to cock it up!
I've got two problems:- 1. My brake sensor warning light can't be reset on the dash, saying Reset Not Possible. I can't find a way to clear this error, even though I've replaced the sensor and pads (I've even tried wiring the sensor out just in case my new ones bad!). This was my main reason for getting plugged in to the car. 2. Even more annoying, while I was plugged in and had E-SYS connected I thought I'd have a go at recoding my head unit to give me advance bluetooth... I now have a head unit with no bluetooth at all, no USB either, and thinks it's a Bang & Olufsen!... It's only a HU_ENTRY Just to add insult to injury, I can't change it back. I set the FA code back from 6NK to the original 6NH, but I can't right click and 'CODE' the HU_ENTRY... there's no CAFD file under the HU, and the 'Detect CAF for SWE'. is greyed out I've checked and I don't have a combox in the boot, if that helps I'm using 3.28.1 that came with the cable I bought, and v.63.3 PSdZData_lite that came with it too. My car is a 2012 F30 320i Please help me at least get my head unit doing what it used to do!...bluetooth phone and USB music! Anything more than this would be a bonus at this point. If the brake sensor thing could be reset that would be a bonus! I'll hang fire trying to upgrade my autobox at this point Any help would be greatly appreciated |
01-10-2021, 10:59 AM | #2 | |
Rep 16,079
KHH1.50 |
01-10-2021, 11:20 AM | #3 | |
Rep 2,302
With the 3.28, the CAFD assignment works almost never. Here you can download the 3.30. https://mega.nz/file/UDBGVRIY#4c6l5z...jb6xkqjiaQW6uI Try it again with this version. |
KHH1.50 |
01-10-2021, 12:26 PM | #5 | |
Rep 10
Also, is there anything I need to make sure of with the PSdZData file? |
01-10-2021, 01:08 PM | #6 | |
Rep 2,302
But for your problem (change VO and Code an ecu) you don't need a token or Launcher. You can use your old psdzdata with it. |
KHH1.50 |
01-10-2021, 01:23 PM | #7 |
Rep 10
Great, thanks!
KHH... Killa Hedgehog... Mr Hedgehog to you
01-10-2021, 02:35 PM | #8 |
Rep 10
I assume I can use the same cable but with different software? Would that be ISTA+? ... sorry, new at this on BMWs
01-14-2021, 02:03 PM | #10 |
Rep 10
Still no luck with this!
I've used a newer version of the software (thanks atzebmw), and have been able to use the 'Detect CAF for SWE' which v3.28 wouldn't allow... but it comes up with 4 options... No worries me thinks, I'll just work my way though them until I find the right one... Nope! I've tried a couple of different version of setting in the FA coding 6NH (original), 6NS, 6NK, 6NL. At the moment I'd just like to restore the original functionality, but what ever I try I get a version of this... And this... Is it possible my copy of v.63.3 PSdZData_lite is fubar and causing this, or that I'm just doing it wrong?! Also is there any way of finding out what the CAFD should be for me HU_entry Any help would be very much appreciated!
01-20-2021, 11:50 AM | #12 | |
Rep 10
Thanks! I'll get back to you
01-20-2021, 12:29 PM | #13 |
Rep 133
I'm gonna take a left turn on this topic since its loosely related to a question I have about these cars. Sounds like I have the same radio set up you do in my '14. However, the car has NEVER recognized a plugged in iphone or whatever to the USB as a valid source of music. Is this working as intended? Is the USB plug only for mp3's saved to a thumb drive or something? Or is something messed up on our car?
Thanks anyone who can help |
01-20-2021, 01:29 PM | #14 | |
Rep 10
My phone however bluetoothed to the headunit fine for phone calls but nothing else. It now doesn't even do that FUBARed it!
01-20-2021, 03:44 PM | #15 | |
Coding ECU's remotely
445
Rep 1,176
Author of Car Connector - remote ICOM & ENET tool - Built in VPN for easy coding and remote diagnostics
Car Connector on YouTube |
01-23-2021, 01:10 PM | #16 | |
Rep 10
Thankyou Wibbles, this has taken a great load off my mind!
Wibbles444.50 |
