11-12-2018, 03:40 PM | #1 |
¯\_(ツ)_/¯
945
Rep 1,762
For those curious about 225/45-18 on a staggered setup
Just had my Michelin Ice XI3 winter tires just mounted onto my staggered wheels. 8" front, 8.5" rear.
You can see the stretch is minimal. The 8" is the top wheel in the first pic, then the first of the set
11-16-2018, 02:31 PM | #2 |
Rep 2,653
Same staggered setup on my wheels with 225/45/18 all around, no issues and minimal stretch. It's a nice alternative.
Solidjake945.00 |
11-16-2018, 02:49 PM | #3 |
¯\_(ツ)_/¯
945
Rep 1,762
Yup yup. This is what everyone with 18" wheels should be running.
11-16-2018, 02:57 PM | #4 |
Rep 2,653
You think this setup would be OK all year round?
11-19-2018, 12:00 PM | #5 |
Rep 891
The stretch here is really minimal, I wouldn't forsee any issues if it was run all year with any tire of your choosing.
OP, those X-Ice look excellent, enjoy.
11-19-2018, 12:28 PM | #6 |
A family of bimmers
2747
Rep 7,742
Looks good. Im running 235/45/18 on 8.5's all around.
11-19-2018, 02:57 PM | #7 |
¯\_(ツ)_/¯
945
Rep 1,762
That's my summer setup
11-20-2018, 03:51 AM | #8 |
Rep 192
This is what I drive year round on UHP summer tires albeit on 8" rims on all four corners. Love the combo and more than enough grip at the rears. I do wish the front end more grip. I can only imagine this situation gets worse with a staggered setup...
11-20-2018, 09:40 AM | #10 | |
Rep 891
11-20-2018, 10:29 AM | #11 |
Rep 192
Interesting... My current tires are shot so I'll be replacing them soon. I'll definately consider throwing something wider in the front than the rear...
11-20-2018, 12:24 PM | #12 |
Rep 891
Just to clarify, I'm suggesting upping the front AND rear size from 225 to 245.
11-20-2018, 02:44 PM | #13 |
Rep 192
I know that running wider tires at the front than the rear is weird as heck, but if I go to 245s all around wont I just be gaining overall grip and maintaining my currently understeery balance?
11-20-2018, 04:05 PM | #14 | |
Rep 891
I do get what you mean with your question, I would caution that there could be unintended consequences stemming from general stability or braking or introduction of snap oversteer. To change that fundamental balance you need to make mechanical changes which are unfortunately more costly. Our cars suffer from a lack of negative camber up front and even worse it's not adjustible. You either need to 1) lower the car 2) Install -.5 correction hubs or 3) install control arms or camber plates. I went for a combination of 1 and 3, coilovers and control arms. Now that my camber up front is about even with the rear it has a very neutral balance. Camber is not the be-all-end-all on this of course, but tire width and camber are two of the most direct ways to up your front grip.
11-21-2018, 03:43 AM | #15 | |
Rep 192
So far I've lowered the car, but it's dropped less than I expected. The Eibach Pro-Kits are known for not droppping all that much but I was hoping for at least an inch... I got about half of that. However paired with Bisltein B8s the ride and handling have improved dramatically. I know lack of camber on these cars is a major issue. It also causes my car to EAT the outside of the tires even though I'm running very little toe-in... I'm considering camber plates but those are expensive as hell and while looking into them I've read that most options actually tend to RAISE the car... Which isn't that bad with coilovers but it's a death sentence with fixed length strut and spring combos... You did the M3 LCA conversion? Is the wheel sitting very far forward in the arch? This is something I've been wanting to do really badly but I'd rather keep the wheel centered... As it is, the car drives great, I mean this is just a lowly 420i with springs, struts, ECU flash and Msport blue brembos and the thing goes, turns, stops and even drifts if you really go for it despite the lack of an LSD... But we're always looking for that little bit extra aren't we? |
11-21-2018, 08:44 AM | #16 | |
Rep 891
Absolutely a big problem. I've experienced the tire eating you're talking about with three different stock F30's at autocross. One of them had OE RFTs with only a few thousand miles on them and it had to retire early because the outer shoulder wear made the sidewall split and start peeling back down to the belt. I have also seen camber plates raise the front end but the main reason I stay away from plates is noise, they'd definitely allow some healthy camber, though. Yes and yes. The wheel shifted forward around half an inch. If you do the Tension struts at the same time it would shift it about half as far than with LCAs alone. It was a very worthwhile mod for me, the difference on track was very pronounced and I cut seconds off my times not having to worry about shredding the outer sidewalls. I'm sure it's driving well with all that, but you're right, we're always looking for that next improvement.
11-24-2018, 06:24 PM | #17 | |
Rep 109
245 / 40 alpin pa4 on 8" 397 wheels. I m surprised how well the 245 fit on the 397. |
