09-28-2018, 07:50 AM | #13797 |
Rep 40,772
PM sent.
09-28-2018, 08:04 AM | #13798 |
Rep 8
hello to all guys, I'm new to the site. I introduce myself to Manuel and I have a Bmw F20 118D Sport.
I hope to find myself on the right page and not to create useless messages. I hope that at least you can help me. For almost a month I was upgraded to my Bmw F20 and as a result of this I was inserted the double horn when I close the motor car in operation. after having gone through several bmw to disable it without any success, I decided to buy the enet cable with the e-sys 3.25 program and psdzdata v.63.3 lite. After having performed the whole connection procedure unfortunately I can not code the fem to disable these two horns due to the following errors: Transaktions-Report: Aktion: Codierdaten lesen ACSM [1] [*******] readCPS o.k. CAFD_00000911_004_001_002.ncd generated ACSM [1] [*******] readCPS o.k. CAFD_00000912_004_000_000.ncd generated ACSM [1] [*******] readCPS o.k. CAFD_00000913_003_005_004.ncd generated BKOMBI [60] [*******] readCPS o.k. CAFD_00000760_007_003_032 Fehler: File for "cafd_00000760-007_003_032" not found! [C012] DME [12] [*******] readCPS o.k. CAFD_000001A7_000_018_006 Fehler: File for "cafd_000001a7-000_018_006" not found! [C012] SDC [29] [*******] readCPS o.k. CAFD_000009EF_000_024_002.ncd generated EKPM2 [17] [*******] readCPS o.k. CAFD_00000098_000_008_113.ncd generated EPS [30] [*******] readCPS o.k. CAFD_00000C77_000_007_001.ncd generated FEM_BODY [40] [*******] readCPS o.k. CAFD_00000794_017_068_021 Fehler: File for "cafd_00000794-017_068_021" not found! [C012] HU_ENTRY [63] [*******] readCPS o.k. CAFD_000000F9_007_009_009.ncd generated ICM [1c] [******] readCPS o.k. CAFD_0000067B_002_003_148.ncd generated IHKA [78] [******] readCPS o.k. CAFD_00000A3F_005_001_019.ncd generated REM [72] [******] readCPS o.k. CAFD_000007A1_005_044_011 Fehler: File for "cafd_000007a1-005_044_011" not found! [C012] ZBE2 [67] [******] readCPS o.k. CAFD_00000D37_001_000_000.ncd generated can you help me kindly? I thank you from the heart. |
09-28-2018, 08:07 AM | #13799 | |
Rep 40,772
09-28-2018, 08:19 AM | #13800 |
Rep 8
09-28-2018, 08:27 AM | #13801 |
Rep 40,772
Let me say it a 2nd time. You cannot send or receive PM's yet, but send me one when you can. This should be less than 1 hour. You can't wait?
09-28-2018, 08:31 AM | #13802 |
Rep 8
09-28-2018, 08:41 AM | #13803 |
Rep 40,772
It's working now. PM sent.
09-28-2018, 12:59 PM | #13805 |
Rep 40,772
Cheat Sheets are no longer used, replaced by Cheat Codes built into E-Sys Launcher. Mac OS not supported, nor is Windows Virtual Machine, so Bootcamp is only option. PM sent.
09-29-2018, 08:29 AM | #13807 |
Rep 40,772
PM sent.
09-30-2018, 06:08 PM | #13809 |
Rep 40,772
You cannot send or receive PM's yet. Send me one when you can.
10-01-2018, 01:21 PM | #13811 |
Rep 48
Anyone got an issue with not being able to start the E-SYS launcher and have you found a solution? I've got the latest .Net update and am using Windows 7.
The application starts (when looking in application management) but consequently shuts down without showing up. The only forum I found with the issue had a updated windows 7 to windows 10 and solved the issue by reinstalling Windows. I would like to use the app without such a "dire" solution. |
10-03-2018, 12:15 PM | #13812 |
Rep 2
Hi Shawn,
my F36 was serviced today and the dealer "helpfully" updated the firmware so I lost all my customizations and my E-Sys/pszdata are from late 2016. Could you please send me a link to the latest sw? Thanks! |
10-03-2018, 12:30 PM | #13813 | |
Rep 40,772
acr12714.50 |
10-03-2018, 12:31 PM | #13814 |
Rep 40,772
Did you attempt at some time to change System Date back in order to rearm Launcher premium after it's Token expired?
10-03-2018, 08:00 PM | #13815 |
Rep 78
My 2014 F34 was serviced for the sunroof and trunk switches recently, and they must have flashed me to a new software version when they initialized, because some of the interfaces look more like what was in the 2019 X3 loaner I had during the service. Needless to say, my codings are wiped out.
I'm thinking it's best to start with the latest software from scratch. Please PM me the details. I'm hoping I'll finally be able to "comfort close" my GT Hatch... Anybody know about that? Last I heard, the 2015 GT could do it, but I'd need to update the "iStep" to code it to mine, which was ill-advised to do on your own at the time. Thanks! |
10-03-2018, 09:15 PM | #13816 |
Rep 15
HELP!Drive Control Switch Unit error
I have an old idrive controller. After the host upgrades the EVO system, pressing the TEL button displays the navigation interface. Pressing the RADIO button is actually the media menu, which seems to be the function corresponding to the new control value button. How to code to correct the problem that the button function does not correspond?
