06-13-2021, 12:00 PM | #1 |
Rep 4
F30 N20 vs N55 Common Problems & Reliability Issues
Hello everyone,
Could you share your thoughts regarding "F30 N20 vs N55 Common Problems & Reliability Issues" I was read a lot about these engines but nothing compare to the real deal owner answers. - Which year is preferable? Like At least 2014 - What are the most common problems. After buying the car it's must to look into these problems afterwards consider changing/fixing Example (most common problems): - Timing Chain - Valve Cover and Valve Cover Gasket - Water Pump Failure - Leaking Oil Filter Housing Gasket - VANOS Solenoid Failure - High Pressure Fuel Pump Failure (HPFP) – Mostly older models - Real consumption (stock car) - City (with 50-60 km/h) - Highway (100-140km/h) Second thoughts should i think about B48 and B58 instead of N20 and N55 More words about the xDrive system and what to expect there as weak spots and repairs. In the end I am looking mostly for reliability. Less problems and less expensive repairs. Thank you in advance. |
06-13-2021, 08:33 PM | #2 | |
Rep 1,119
Drives: 2015 BMW 435i Xdrive MSport
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily) |
06-14-2021, 06:45 AM | #3 | |
Rep 4
I don't like Toyota. If we talk about the total reliability than we go with Mazda. I am not saying having a BMW you don't have any problems. The point is to having less problem like "timing chain" causing by BMW by default. About fixing the time chain what do you mind? If this is changing the time chain kit this is not an issue. |
06-14-2021, 08:34 AM | #4 | ||
Rep 85
-Ryan H
sspade2464.50 Boostedphil698436.00 |
06-14-2021, 08:43 AM | #5 |
Rep 562
Drives: 2017 BMW 330i xDrive
Factory N20 issues include the timing chain and transfer case. Both have available parts to permanently fix the issue.
N55 does not suffer from timing chain issues, however the transfer case has the same weak point. That being said, since the failure is accelerated by prominent engine vibration and the N55 produces very little, transfer case failures with the N55 are very rare. Stock for stock, the N55 is likely to be more reliable. You mentioned that you were also considering the B48, if you want to go the four cylinder route, that would also serve you well. Both the timing chain and transfer case issues were fixed by the time the B48 came around.
2017 330i xDrive Imperial Blue Exterior / Venetian Beige Leather with Oyster Accent Interior / Anthracite Wood Trim |
06-14-2021, 09:25 AM | #6 |
Rep 5,457
Have approximately ~90k driven over two vehicles with the N20 motor (both RWD) and have literally only had one issue... the coolant thermostat replaced on my 2014, covered under extended factory warranty (free of charge).
In my experience this motor has been extremely reliable although not known for being as smooth or quiet running as inline six brethren. Run quality fuel and change oil often. Don't abuse when cold. 35mpg highway cruising at 80mph. Preferable to purchase an N20 with a mid to late 2015 build date. Last edited by sspade; 06-14-2021 at 09:35 AM.. |
RMachuca3d723.50 razzy53082.00 |
06-14-2021, 09:41 AM | #7 |
Space Shuttle Door Gunner
6430
Rep 5,309
06-14-2021, 03:24 PM | #8 |
Rep 85
Google translate is a hell of a thing or don't you have that in Bulgaria
-Ryan H
06-14-2021, 08:34 PM | #9 |
Rep 3,752
Go either motor, like everyone said it's an expensive car to repair but I see 80s, 90, 2000s and 2010s running around....maybe those are properly maintain BMW, who knows
Good luck |
06-15-2021, 03:03 AM | #10 |
2JZ-GTE
3032
Rep 3,992
06-15-2021, 04:40 AM | #11 |
Rep 1,268
I've had my F30 335i (N55) for a couple years now. It was until last month the most reliable car i've ever had. Noticed smoke creeping up from under the hood at standstill traffic. Ended up having the valve cover gasket & oil filter gasket changed under warranty.
If you can, get an extended warranty for absolute peace of mind. |
06-15-2021, 09:55 AM | #12 |
6430
Rep 5,309
06-15-2021, 11:23 AM | #13 |
Rep 323
2012 335i F30
I've noticed leaky window seals on front two windows that makes car sound like an economy car at highway speeds. The car uses about 1/2 a quart oil every 5000 miles. The harmonic balancer appears to have a slight wobble too that is noticeable when idling that makes it sound less than perfect as it causes the tensioner to spring back and forth. Sometimes there have been mystery noises when gassing hard from turbo that have appeared and vanished. Other times when pulling into garage before shutting off engine there is screech noise which is probably pcv or vent hose diaphragm failing which eventually requires new valve cover |
iScramble76.00 |
06-15-2021, 11:36 AM | #14 |
Rep 425
I've noticed what I think you're describing here. You think it's the Valve Cover gasket that needs replacing? Would there not be evidence of an oil leak?
2013 328i M Sport, Estoril Blue, Venetian Beige, Walnut trim, 8AT, Premium, Cold Weather, Lighting, Technology, Navigation, Driver Assistance, HK Sound
06-16-2021, 02:05 PM | #15 |
Rep 133
BMW fixed the N20 timing chain issue with their 2016 and up N20s, although I believe the B48 became available around that same time, personally I'd go for the B48 over the N20, should be priced almost identically but the B48 seems to have a bit higher of a tuning ceiling with less of the N20's problems.
