BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Can someone recommend for H7 LED bulbs?
      11-29-2021, 11:55 AM   #1
orha12
Drives: BMW F30 316i
I have now stock H7 halogen bulbs on my f30.
Until i will buy a new led headlights, i will start with LED bulbs.
Any recommendations?
Coding ia not a problem for me (Bimmercode).
      11-29-2021, 12:47 PM   #2
sspade
sspade's Avatar
Drives: F30
2016 BMW 320i  [7.87]
2014 BMW 328i  [6.83]
I really liked the Morimoto 2stroke 2.0 bulbs on my pre LCI halogens. Direct fit without adapters and super bright/white light. That being said, I was never flashed for dazzling oncoming traffic. Being slightly lowered probably helped.
      11-29-2021, 02:59 PM   #3
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
If I was in the market for them today I'd get these:
https://www.amazon.com/BEAMTECH-H7-L...219508&sr=8-46
      12-01-2021, 10:19 AM   #4
thumperwhite
thumperwhite's Avatar
Drives: F30
Is Horizon LED still in business? Over the last 3 weeks I have sent several emails asking for specific product recommendations, since they have several LED bulbs for each application...H7 &H8. No response.
      12-01-2021, 11:37 AM   #5
chowser51
chowser51's Avatar
Drives: F33 430 and F39 M35i
I have Beamtechs in my daughter's Subaru and other than icing issues during winter storms, they're great. I'm looking into the Morimoto 2Strokes which solves this issue.
      12-01-2021, 11:48 AM   #6
Billfitz
Billfitz's Avatar
How are they icing? I've never had that happen.
      12-01-2021, 11:58 AM   #7
gameson
Drives: 2015 BMW 320i N20
this one has heat sink on bottom, will the heat cause any melt inside the housing?
thanks.
      12-01-2021, 01:15 PM   #8
Billfitz
Billfitz's Avatar
All LED bulbs have heatsinks. Some even have fans to increase their effectiveness, but fans tend to fail, and they're only used on LEDs than are brighter than necessary. Fanless LEDs are at least three times brighter than halogen.
      12-01-2021, 04:19 PM   #9
chowser51
chowser51's Avatar
It’s not really icing but during heavy snowstorms snow starts to stick over her Subaru Impreza headlights when using the Beamtechs. The assembly doesn’t get warm enough to melt unless she turns on her (halogen) highbeams. It only happened a few times last winter.
It looks like the morimotos fan some heat back into the housing which would keep the assembly warm.
      12-01-2021, 04:52 PM   #10
Billfitz
Billfitz's Avatar
I doubt that the Morimotos will be any help there. Halogens create heat when lit, a lot of it. Some 90% of the current in halogens, or any incandescent bulb, is lost as heat. That means a 55w H7 is a 50 watt heat source, with most of that being infra-red radiation. That's what heats the lamp lens. Some 80% of the current is lost as heat with LEDs, but it doesn't amount to much, as they only drop around 15 watts total, and produce almost no infra-red. The fan cooling is only there to prevent damage to the LED, which suffer from reduced output if they overheat.
I coat my lenses with Jescar Power Lock, the same as I do the rest of the car. They shed water, and judging by my lack of snow build up they shed snow as well.
      12-02-2021, 02:48 AM   #11
orha12
So you suggest i should go with Beamtechs?
      12-02-2021, 04:03 AM   #12
sspade
sspade's Avatar
Drives: F30
If you want one to burn out, yes. Thats what happened to me which is why I went with the Morimotos which are worlds better in terms of quality.
      12-02-2021, 04:09 AM   #13
sspade
sspade's Avatar
Drives: F30
Check the dates from my eBay purchases page. Within 6 months one of my Beamtech's burnt out. Junk!
      12-02-2021, 04:20 AM   #14
sspade
sspade's Avatar
Drives: F30
Forgot to mention… the Morimoto's use genuine CREE XHP50 LED chips. Wonder what Beamtech is using?
      12-02-2021, 07:26 AM   #15
Billfitz
Billfitz's Avatar
I believe that I already did.
You can get made in China Beamtechs, or brands with Japanese or German sounding names that are also made in China. The Broview branded LEDs that I have were also sold under the Weisslicht brand, at three times the price. A little investigation reveals that there is no Weisslicht factory. Caveat Emptor.
      12-02-2021, 09:48 AM   #16
gameson
my car has xenon headlights, would this led bulb work? thanks.
      12-02-2021, 10:17 AM   #17
Billfitz
Billfitz's Avatar
If you have HID xenon there's no point in going to LED, if you could, which you can't, because they don't make LED bulbs that fit into HID xenon lamps.
      01-05-2022, 10:14 PM   #18
boyerizm
boyerizm's Avatar
Drives: BMW 328i xDrive M-Sport
Yeah I'll second the morimoto's, I'm running them now. They aren't cheap but quality.
Make sure you buy them from their website if you do, that's the only way they will honor the warranty.
      01-06-2022, 07:46 AM   #19
Billfitz
Billfitz's Avatar
They're probably OK, but despite the company taking the name of a well known Japanese chef for instant brand name recognition it's still Chinese stuff made by CNLight. Like Smokey Robinson's mamma told him you better shop around.
      01-06-2022, 01:51 PM   #20
boyerizm
boyerizm's Avatar
Sorry, a bit off topic, but anyone retrofit angel eyes into their halogens?
I found this https://www.bavgruppedesign.com/prod...en-headlights/
Really liking the look of the eyebrow light, the angel eyes are so so.
      01-06-2022, 09:48 PM   #21
Billfitz
Billfitz's Avatar
Pulling the lens from the lamp isn't easy.
      01-06-2022, 09:54 PM   #22
Hammer Werke
Drives: '15 328d Touring
Ive been running the Hikari UltraFocus for 4 years. They are great. Huge improvement over stock halogen.
