08-09-2020, 01:43 AM | #111 | ||
Rep 106
08-13-2020, 06:24 AM | #113 |
Rep 2
Hi. I've just purchase the Road Top CarPlay from Amazon for my 2014 F30, relatively easy to install and everything is working correctly apart from the tone from the parking sensors.
When I go into reverse the screen switches to the Parking Sensor screen as normal but there's no tone / beep when it detects an obstruction. Has anyone else found a workaround for this? |
08-19-2020, 08:16 AM | #114 | |
Rep 35
08-27-2020, 10:44 PM | #115 | |
Rep 77
Hopefully, everything will work out Last edited by Fishie; 11-01-2020 at 12:19 PM.. |
09-30-2020, 12:52 PM | #116 |
Rep 963
man have i been searching for this thread for years. don't know how i did not find it earlier. i have a 09/2012 build and am 95% sure i have CIC High with the 6 pin connector. going to order the Road Top NBT version and try this out.
it sounds like the mic tap comes with the NBT version from road top. the one question i have is, has anyone wired in a backup camera with this MMI? i don't have a backup cam and was thinking of doing that retrofit at the same time.
2018 Azurite Black F80 M3 ZCP
2019 Phytonic Blue G05 X5 2013 Glacier Silver F30 335i (sold) |
10-15-2020, 04:41 PM | #117 | |
as long as it runs :)
40
Rep 164
aps335.50 |
10-16-2020, 06:05 PM | #118 | ||
Rep 50
10-28-2020, 09:00 AM | #119 |
Rep 963
just picked it up off amazon and a backup camera. going to try the install this weekend!
11-03-2020, 07:14 PM | #120 |
Rep 963
So I installed this Road Top unit over the wknd and it's been great so far. Impressed with the wireless connectivity on initial startup. Almost immediate. There is sometimes an input delay, but that's been the only somewhat negative I can think of.
I confirmed that I had CIC_High and the NBT plugs worked without any issues. I did run the mic extension over to my OEM mic which also functioned immediately as expected. I ran out of time to wire up the aftermarket backup camera that I bought separately, which is honestly the main reason I bought this unit, so that'll be the next project, but very happy with this MMI. Thanks to everyone in this thread for their feedback!
11-06-2020, 02:13 PM | #121 | |
Rep 2
1) As you have the larger OEM display, does carplay fill the screen or only do half of it..I've seen some units do the later and want to avoid it. 2) When you say you ran the mic extension, did you replace the OEM mic, splice it in, or did it come with a plug and play adapter? Thanks! |
aps335.50 |
11-06-2020, 04:20 PM | #122 | ||
Rep 963
1. it fills the whole screen. I would have returned it if it was only partial because I agree, it is way better with full screen. 2. mic adapter was 100% plug and play. ran the wire across the steering column and up into the headliner. kiesmotorsports has a good video on how to do this and the adapter looks the exact same as the bimmertech plug and play adapter.
11-15-2020, 04:50 PM | #123 |
Rep 8
Wow am I ever glad I found this thread!
So around a week ago I ordered a CIC MMI box for my 2012 f30 - after doing some more digging regarding the setup process I’ve come across a few people who run into the 6 pin CIC issue. I pulled off my screen and low and behold - 6 pins! Luckily - AliExpress hasn’t shipped my order yet so I was able to cancel. I’ve read through the whole thread but have a few questions here before moving forward with purchasing the road top unit 1. Can you guys confirm based on the attached photos that I’m dealing with the same situation as everyone else in this thread (6pin CIC/CIC_high) 2. If this is the case, is this the right box to be going with - with the mic tap and everything else needed included? https://a.aliexpress.com/_mOchrct 3. I’m regards to the mic tap process, can someone go into detail what that entails? If I want to use the OEM mic do I have to run up the A pillar to tap into it? Or is it just a connection I can do on the back of the head unit 4. With the box I sent , I’ve seen a few people say they need to run an aux cable and a few say it’s plug/play. Will I have to pull up my centre console trim and run an a cable from the box to the AUX in port? Or am I misunderstanding here Thanks in advanced guys! So grateful this thread exists at all, nevermind it being so recent. |
11-15-2020, 08:04 PM | #124 | |
40
Rep 164
11-16-2020, 08:02 PM | #125 |
Rep 963
Couple updates on my Road Top unit:
1. wired up an aftermarket reverse camera with no issues. camera has a yellow RCA male connector that plugged into the carplay unit. sourced camera power in the REM fuse box in the trunk. fairly straightforward install and picture quality is great. made sure to check the aftermarket camera box in the settings and camera flips on as soon as I throw it in reverse. 2. Sound quality - so over the last 2 weeks, I had gotten increasingly bummed out about the sound. I had been running the audio through the Aux input, which I thought was required. At first, the quality didn't seem that bad, but over the last week, it seemed like every song was flat and lacked depth. Even after spending some time with the EQ settings. I knew to kind of expect this given that USB keeps the audio digital and Aux is basically super old tech, but I thought it wouldn't be so obvious. So I was messing around with the iDrive inputs today and either I am an idiot and/or I misread something in all the research, but I figured out you can run the sound through USB (on iDrive) and still flip back to the Carplay screen to control the music! As soon as I switched the input, the sound quality was back to full depth and bass! The difference was way more noticeable going from Aux to USB. Now I basically have zero reason to go to the iDrive other than checking error messages or whatever. Running the audio through USB with wireless Carplay makes this a no-brainer at $250ish. Zero reason to go for a full fledged headunit upgrade when I can retain OEM sound quality and also add Carplay, backup camera. Feel like I have the best of both worlds now
11-16-2020, 08:39 PM | #126 | |
Rep 268
aps335.50 |
11-24-2020, 04:23 PM | #127 |
Rep 14
Hey guys I have 2017 F31 can I turn carplay on with a simple file on a flash?
I have the large screen, touch pad, wifi antenna, wireless charging, nav and large display in the dash. S609 Nav Pro S6w6 WLAN S6WA Panel with extended scope S69W wireless charging |
11-25-2020, 02:50 AM | #128 |
40
Rep 164
Do you have the nbt evo? If so most likely you just need to activate CarPlay
11-25-2020, 05:21 PM | #130 | |
Rep 8
Also separate to this, anyone have any luck coding out the voice button on the steering wheel so it does not trigger the BMW voice assistant, and just Siri? I have found some guides on how to do this on the true NBT units using bimmercode, but no luck with our CIC high setups |
12-01-2020, 01:04 PM | #131 |
Rep 11
Hi all,
I also own a 2012 F30 with CIC_HIGH with 8.8” display and have tried 2 different options to get carplay to work. In 2018 I ordered a carplay kit from ali for a CIC system, the seller told me it would be compatible with my car but off course this kit had a 4 pin lvds connector for the display and gave a ‘no signal’ error... After that one I got the carplay mmi from bimmertech, which did work, but had horrible picture quality, it looked like there was an extra digital to analog conversion going on, the colors looked like a console system on a composite video connection. Also the audio was really flat and dissapointing.. So I kind of gave up on carplay then, but recently I’ve been looking around and found this thread. I saw woodcutter mention that in order to get the audio to work, you need to order a unit with a separate aux connection because aux spliced into the connector on the cic does not work. I’ve been googling around and found a possible solution to that problem: The cic unit DOES have aux on it’s block connector, but on our cars this input is disabled because we have the combox installed, however it should be possible to enable this input again by coding it. source: https://www.e90post.com/forums/showp...7&postcount=25 (full thread -> https://www.e90post.com/forums/showthread.php?t=1569700) I also found something interesting about the microphone input, I re-read the bimmertech installation manuals for their MMI box, they have a version for units with and one without combox, and only the installation for the combox version needs the aux cable and the microphone splitter cable, they both use the same MMI model and rest of the cables. So it seems that, with a combox installed, both AUX en microphone inputs on the CIC_HIGH unit are disabled, which makes sense, they come from the combox. At least the AUX input should be codable, but possibly also the microphone input Did any of you get a NBT carplay kit with audio through the block connection, and if yes, can you test if this works? Because I’m curious if there is any quality difference when using this aux input instead of the on in the armrest (which has extra resistors and capacitors) Edit: jared21927 I saw you mention in this thread you use BT for audio because your kit does not have a separate aux connector, is this correct? which kit did you get? Last edited by BreeeZe; 12-02-2020 at 02:16 AM.. |
12-02-2020, 11:30 PM | #132 | ||
Rep 963
