01-21-2020, 02:24 PM | #45 | |
Rep 11
Thanks again!! |
01-22-2020, 01:43 PM | #46 |
Rep 270
I used the harness below.
https://www.ebay.co.uk/itm/BMW-F32-F...sAAOSw8ttc-USX I didn't connect the indicator wires directly into the REM, instead I posi tapped onto the existing outer indicator wires using connectors from amazon. Left indicator: black & white striped wire running into the far right plug on the REM module Right indicator - grey & black striped wire running in the left plug on the REM module (not middle) https://www.amazon.co.uk/Connectors-...39833323&psc=1 All I needed to code was all rear lamps to LED from Bulb. Very simple with the bimmercode app.
2017 F36 440 LCI - Smoked Topaz | Auto | M Sport Plus | HUD | ICON Adaptive Headlights
01-23-2020, 05:18 AM | #47 | |
Rep 11
04-13-2020, 10:22 AM | #49 |
Rep 111
I did this mod on my F36 this weekend. What a PIA nightmare! Mick is right, you need to drop part of the headliner in order to get to a connector and a large plastic harness router clipped into the roof. This was the most challenging part for me. I would not want to go through it again for sure
04-17-2020, 05:25 AM | #50 | ||
Rep 2
04-17-2020, 01:56 PM | #51 | |||
Rep 270
I bought the same ones, they come as a pair.
Jayfndzz0.00 |
04-17-2020, 02:02 PM | #52 | ||||
Rep 2
04-17-2020, 02:07 PM | #53 |
Rep 270
The OEM LCI harness is plug and play with the LCI lights.
Make sure you buy the correct OEM harness -F32, F33, F36 etc as they will be different cable lengths.
10-05-2020, 08:42 AM | #54 |
Rep 71
Can the Lci lights be coded with the bimmercode app on my phone?
I've got some lights coming soon & I have ordered this.... Do I need to order anything else? Last edited by OcTag3n; 10-05-2020 at 12:37 PM.. |
10-08-2020, 06:10 PM | #55 | |
Rep 3,863
Yes you can code lights with BimmerCode app . Not sure about this harness I bought OEM one . Outside lights easy to fit and no need coding but taillights a lot of work involved removing tailgate trims etc and wire loom When you removing look take pics of each connectors so you know wheee to plug new loom , it’s fiddly but take your time and it’s doable |
OcTag3n27.50 |
10-10-2020, 03:42 AM | #57 | |
Rep 3,863
REM_01 > LceLampMapping1 3062 > MAPPING_BLINKER_H_L_PWM_LEVEL_1 = 13.7V [Default] REM_01 > LceLampMapping1 3062 > MAPPING_BLINKER_H_R_FIXED_PWM = fixed REM_01 > LceLampMapping1 3062 > MAPPING_BLINKER_H_R_PWM_LEVEL_1 = 13.7V [Default] REM_01 > LceLampMapping1 3062 > MAPPING_BRAKEFORCED_L_FIXED_PWM = fixed REM_01 > LceLampMapping1 3062 > MAPPING_BRAKEFORCED_L_PWM_LEVEL_1 = 100% [Default] REM_01 > LceLampMapping1 3062 > MAPPING_BRAKEFORCED_R_FIXED_PWM = fixed REM_01 > LceLampMapping1 3062 > MAPPING_BRAKEFORCED_R_PWM_LEVEL_1 = 100% [Default] REM_01 > LceLampMapping1 3062 > MAPPING_BREMSL_L_FIXED_PWM = fixed REM_01 > LceLampMapping1 3062 > MAPPING_BREMSL_L_PWM_LEVEL_1 = 13.5V [Default] REM_01 > LceLampMapping1 3062 > MAPPING_BREMSL_R_FIXED_PWM = fixed REM_01 > LceLampMapping1 3062 > MAPPING_BREMSL_R_PWM_LEVEL_1 = 13.5V [Default] REM_01 > LceLampMapping2 3063 > MAPPING_NEBELSCHLUSSL_L_FIXED_PWM = fixed REM_01 > LceLampMapping2 3063 > MAPPING_NEBELSCHLUSSL_L_PWM_LEVEL_1 = 13.5V [Default] REM_01 > LceLampMapping2 3063 > MAPPING_NEBELSCHLUSSL_R_FIXED_PWM = fixed REM_01 > LceLampMapping2 3063 > MAPPING_NEBELSCHLUSSL_R_PWM_LEVEL_1 = 13.5V [Default] REM_01 > LceLampMapping2 3063 > MAPPING_RUECKFAHRL_L_PWM_LEVEL_1 = 13.7V [Default] REM_01 > LceLampMapping2 3063 > MAPPING_RUECKFAHRL_R_PWM_LEVEL_1 = 13.7V [Default] REM_01 > LceLampMapping2 3063 > MAPPING_UNIVERSAL_6_OUTPUT = sl_2_l REM_01 > LceLampMapping2 3063 > MAPPING_UNIVERSAL_7_OUTPUT = sl_2_r REM_01 > LceLampMapping2 3063 > MAPPING_UNIVERSAL_8_OUTPUT = bfd_l REM_01 > LceLampMapping2 3063 > MAPPING_UNIVERSAL_9_OUTPUT = bfd_r REM_01 > LceOutputChannels 3061 > BFD_L_CCM = ccm_blinker_l REM_01 > LceOutputChannels 3061 > BFD_L_IS_LED = aktiv REM_01 > LceOutputChannels 3061 > BFD_L_UE_SPG_SCHUTZ = dimmed REM_01 > LceOutputChannels 3061 > BFD_R_CCM = ccm_blinker_r REM_01 > LceOutputChannels 3061 > BFD_R_IS_LED = aktiv REM_01 > LceOutputChannels 3061 > BFD_R_UE_SPG_SCHUTZ = dimmed REM_01 > LceOutputChannels 3061 > BL_L_IS_LED = aktiv REM_01 > LceOutputChannels 3061 > BL_L_KALTUEBERWACHUNG = nicht_aktiv REM_01 > LceOutputChannels 3061 > BL_L_UE_SPG_SCHUTZ = nicht_aktiv REM_01 > LceOutputChannels 3061 > BL_R_IS_LED = aktiv REM_01 > LceOutputChannels 3061 > BL_R_KALTUEBERWACHUNG = nicht_aktiv REM_01 > LceOutputChannels 3061 > BL_R_UE_SPG_SCHUTZ = nicht_aktiv REM_01 > LceOutputChannels 3061 > FRA_H_L_IS_LED = aktiv REM_01 > LceOutputChannels 3061 > FRA_H_L_KALTUEBERWACHUNG = nicht_aktiv REM_01 > LceOutputChannels 3061 > FRA_H_L_WARMUEBERWACHUNG = aktiv [Default] REM_01 > LceOutputChannels 3061 > FRA_H_R_IS_LED = aktiv REM_01 > LceOutputChannels 3061 > FRA_H_R_KALTUEBERWACHUNG = nicht_aktiv REM_01 > LceOutputChannels 3061 > FRA_H_R_WARMUEBERWACHUNG = aktiv [Default] REM_01 > LceOutputChannels 3061 > NSL_L_IS_LED = aktiv REM_01 > LceOutputChannels 3061 > NSL_L_KALTUEBERWACHUNG = nicht_aktiv REM_01 > LceOutputChannels 3061 > NSL_L_UE_SPG_SCHUTZ = aktiv [Default] REM_01 > LceOutputChannels 3061 > NSL_L_WARMUEBERWACHUNG = nicht_aktiv REM_01 > LceOutputChannels 3061 > NSL_R_CCM = NEW_ccm_nsl_r REM_01 > LceOutputChannels 3061 > NSL_R_IS_LED = aktiv REM_01 > LceOutputChannels 3061 > NSL_R_KALTUEBERWACHUNG = nicht_aktiv REM_01 > LceOutputChannels 3061 > NSL_R_UE_SPG_SCHUTZ = aktiv [Default] REM_01 > LceOutputChannels 3061 > NSL_R_WARMUEBERWACHUNG = nicht_aktiv REM_01 > LceOutputChannels 3061 > RFS_L_CCM = NEW_ccm_rfs_l REM_01 > LceOutputChannels 3061 > SL_2_L_CCM = Fxx_ccm_sl_2_l REM_01 > LceOutputChannels 3061 > SL_2_L_IS_LED = aktiv REM_01 > LceOutputChannels 3061 > SL_2_R_CCM = Fxx_ccm_sl_2_r REM_01 > LceOutputChannels 3061 > SL_2_R_IS_LED = aktiv REM_01 > LceOutputChannels 3061 > SL_L_IS_LED = aktiv REM_01 > LceOutputChannels 3061 > SL_R_IS_LED = aktiv I found coding I used on my F36 using BimmerCode but please if you haven’t done coding first then get someone else to do for £50 which is safer but if you can then even better |
OcTag3n27.50 |
10-10-2020, 04:51 AM | #58 |
Rep 71
That's brilliant! Thank you for posting that information. That will really help me & I'm sure others out when it's coding time.
I've coded quite a lot myself on my old E60 & my F36 using the Bimmercode & carly apps so I should be alright, especially now with the info you have given above. |
UKF302524.00 |
10-10-2020, 06:59 AM | #59 | |
Rep 3,863
Happy to help looking forward see pics fitted mate |
10-17-2020, 08:40 AM | #60 |
Rep 71
Okay so I gave this a go on my Saturday off today.
I got everything installed/wired up. Followed all of the coding to the T (thanks to UKF30) And I can't get nothing out of both inners, no lights at all, dead. I checked everything again & again, it all seems correct, but still nothing. The outers work, but not the inners. There are no errors or warnings in the idrive. I would appreciate it if anybody can help me out, I don't mind paying or taking it to somebody that knows how to get the inners working. This has me beat & I don't know what to do next. |
10-17-2020, 10:36 AM | #61 |
Rep 71
This is how I've spliced into the wires
However, maybe splicing into these wires will work for me? Can somebody tell me the colour of the wire I need to tap into? I have tapped into the black & grey wire on the left plug & black & white wire in the right plug. |
10-17-2020, 11:29 AM | #63 | |
Rep 413
When splicing onto the existing outer indicator wires all you should code is bulb type to LED.
2017 440i F36 - Drexler LSD - B58TU HPFP - MHD Stage 2 - xHP - 200 Cell DP - MPE
10-17-2020, 11:44 AM | #64 |
Rep 71
I followed all of the coding that UKF30 posted. All bulbs are set to led. It must be the way they are wired in or the harness is duff.
I have just sent fortythirtyfive a PM. |
10-17-2020, 01:07 PM | #65 |
Rep 413
You didn't fit the full LCI harness so there was no need to code all them changes....
10-17-2020, 02:09 PM | #66 |
Rep 71
I did not know that. So if I bought an OEM harness, it should work?
I think I have a duff harness. The seller sent me one with a short wire first time around, even though I messaged him that I had an F36 so I sent that back & he sent me this harness. |
