BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N47 and N57 Turbodiesel Engine / Drivetrain / Exhaust Modifications > N57 2013 330d Engine mechanical whine
proTUNING Freaks
      09-21-2020, 04:46 PM   #1
Chris311281
Drives: BMW F31 330d 2013
Hey,
New here and an amateur first post. In short, I have a 2013 F31 330d BMW with 192k km driven. Last month I had a 5k km roadtrip. On the way back, at a stop I noticed a very slight whine / mechanical sound which I'm sure I hadn't noticed before.
Here's the link:
The car had a service prior to departure with no issues. Oil was perfect etc. No errors prior nor after the trip.
My mechanic said he didn't notice any sound. It is slightly intermittent and you might miss it if you don't know what to listen.
I've been told it might just be the phantom sounds of a diesel engine. But I've understood it can also be the high pressure fuel pump?
Everything seems to be running perfectly. Smooth idle, Instant starts, no noticable power loss.
Am I paranoid or is there something I should ask my mechanic to check further?
      09-21-2020, 07:48 PM   #2
Enabled
Drives: 328xd Wagon, M2 Competition
Alternators make whines on F chassis most often
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp
-2016 Mini Cooper S, MT. Many plans.
Others:
-E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe.
      09-22-2020, 12:42 AM   #3
Chris311281
So is my alternator going or is this normal?
I found another thread that seems similar yet they didn't seem to resolve it either :/
https://f30.bimmerpost.com/forums/sh....php?t=1449980
      09-22-2020, 11:02 AM   #4
Enabled
It doesn't mean much until it gets properly diagnosed.
Remove accessory belt temporarily and see if it goes away.
It could be a roller/pulley or alternator or something else.
      09-22-2020, 01:45 PM   #5
Chris311281
It's most likely the AC pump. Remembered the other thread today and turned the AC off and voila! the sound was gone. Going to get it diagnosed.
Thanks for the quick replies!
      08-09-2022, 12:13 PM   #6
bigshooter
bigshooter's Avatar
Drives: 2014 328d xDrive
I have the same issue. 125k miles
      09-09-2022, 06:28 AM   #7
szczepan162
Drives: f31
AC Pomp
diesel, engine, n57, sound, whine
