09-30-2020, 02:45 PM | #23 | ||
Rep 576
10-01-2020, 12:34 PM | #25 |
Rep 72
I'd say it's right around 3/4" in the front and 1/2" in the rear. It's noticeable but subtle. Personally, I think the H&R Sports look the best but was conflicted in regard to ride quality and felt that if Koni packages their shocks with the Eibachs it would be a solid way to go.
2015 - F30 328i RWD Sportline - Mineral Grey - Alcantara/Nappa Steering Wheel with Paddle Shifter retrofit - 437m - Eibach Pro kit with Koni Sports, m3 bump stops.
10-02-2020, 08:31 PM | #26 |
Rep 576
I guess no one wants to share h&r sport or dinan performance photos? Eibachs look nice but I want to have options. I want to close as much wheel gap as possible but I dont want to sacrifice too much ground clearance at the same time.
10-02-2020, 09:33 PM | #27 |
Rep 98
Here ya go H&R Sports
10-02-2020, 09:37 PM | #28 | |
Rep 576
10-02-2020, 09:53 PM | #29 |
Rep 519
keep in mind people's different wheel and tire specs... that will have a lot to do with fender gap...
would probably help if people listed those as well
2017 340i M Sport Alpine White / Coral
Dorch Stg2, CTS catless, xHP, Custom E50 Tuned by Shoup |
10-03-2020, 01:51 AM | #30 | ||
Rep 98
Note: I'm on 18's with stock tire specs. |
10-03-2020, 10:18 PM | #31 | |||
Rep 576
10-05-2020, 11:56 AM | #33 |
Rep 141
Drives: 2016 BMW 340i RWD
Here are few pics of my f30 on dinan springs. I am also running them with koni yellows. Tires are stock oem 19" staggered. I've been running this setup for 2 years with no issues
2016 BMW 340i | DINAN Lowering Springs | DINAN Stage 1 v1 Tune | DINAN Mid Pipe | DINAN CAI | DINAN Turbo Inlet Pipe | Koni Sport Dampers | BMS 12/15 mm Spacers | Active Autowerke Exhaust
10-05-2020, 04:41 PM | #34 | |
Rep 576
10-06-2020, 07:00 AM | #35 | |
Rep 141
10-08-2020, 02:23 PM | #36 |
Rep 576
I'm installing the springs tomorrow with a buddy. Any advice from those of you who have done the install yourself? I went and bought an entire "go thru" ratchet set and also a spring compressor but I believe I have everything else I'll need.
10-08-2020, 04:09 PM | #37 | |
Rep 1,649
10-09-2020, 02:54 PM | #39 |
Rep 576
Ran into a couple dead ends but finally got the front passenger side done. Had to buy a 21mm socket for the tie rod bolt as well as a 3" extension. One more corner to go will post better pics after its all done and driven around the block.
10-09-2020, 06:20 PM | #40 |
Rep 576
Just finished the install! Very pleased with how the car sits ( but I know they will settle). Heres a few pics I took after the test drive but I will get some good quality photos up later on for those who are interested of the eibach pros on a rwd. New wheels and tires to come. First pic of tire gap is after, second is before, and the other 2 are after as well (they downloaded randomly and not in order, sorry). Thanks guys!
10-10-2020, 02:20 PM | #41 |
Rep 576
A couple pics from today after driving around a bit. So far Im very satisfied with not only the drop from the springs but the performance as well. Much more firm but not so firm that the ride quality is diminished. I will make one final post with HD photos once I can get around to pulling out the camera and finding a cool spot to do a shoot the last photo is a before for comparison.
10-12-2020, 03:34 PM | #42 |
Rep 1,649
Looks good! Which part number eibach kit did you get?
I am currently running a set of M3 springs and have a set of eibach E10-20-031-02-22 on the shelf and can't decide if I am going to swap them or not. |
10-12-2020, 06:00 PM | #43 |
Rep 141
Looks good!!
