10-09-2020, 05:11 PM | #1 |
Rep 360
Remap options 320ix 184bhp
Hi,
Wondering what options there are for 184bhp engine. Car has done 101k miles so don't want to push it too much, car is already fairly quick, so might be mapped, but wondering what options would be to get a modest increase while staying safe. |
10-10-2020, 01:56 PM | #3 |
Rep 636
Drives: f32 430ix & 982 GT4 PDK
your car isn't going to be mapped from the factory, and a 320 will be massively undertuned from the factory, so 40-50% power gains are advertised on bm3 website for b48.
My suggestion and what most people run is bm3, which is the most common ECU flash and you won't have any issues even with a stage 2 OTS flash |
10-11-2020, 03:46 PM | #4 |
Rep 360
Hi,
It's the N20 engine and I want to have a safe tune. N20 has a higher compression and different pistons than the 328i N20. There are maps available that offer 260bhp and 400NM from quantum who seem fairly reliable in the UK. Seen a lot of threads of people blowing their engines, which I wouldn't fancy. Any idea on realistic safe remaps numbers for the N20? Thanks |
10-11-2020, 03:55 PM | #5 | |
Rep 636
I only have experise with bm3, but have heard mostly good things about other tunes. PTF advertises gains for 320i here and performance wise in that link |
10-11-2020, 10:32 PM | #6 |
Rep 1,055
You can flash and you'll be golden. I broke 125k miles with my n20 the other day. No issues other than the previous owner previously doing the timing chain repair.
Last edited by sqwinny; 10-13-2020 at 11:21 AM.. Reason: corrected info from official BMW PDF |
10-12-2020, 09:31 AM | #7 |
Rep 20
320i comes with the N20. N26 is the SULEV motor for the 328i
2014 F30 320i | BM3 Stage 2 | xHP Stage 3 | Euromotive Catless Downpipe | GPlus FMIC | MAD Chargepipe | GFB DV+ | 335i Muffler & Resonator Delete
10-12-2020, 11:03 AM | #8 |
Rep 1,055
Sorry man, but that's not the case. N26 is the SULEV motor that is placed in cars within California and is required to meet SULEV standards. The N20 and N26 are identical, however, the N26 has higher compression and less boost from the factory to produce even fewer emissions, and is placed into the 320/328s. N26 has an 11:1 compression, N20 has 10:1. N20 is rated higher from the factory at ~248hp when the n26 is around ~180hp. In theory, the N20 should be able to handle more boost than the N26, however since both motors share the same rods and rod bolts, both of them are limited by torque to around 350-360wtq under 3500 rpm. Thus rod bolts are a minimum to replace if you seek 400whp +.
The real underlying condition is that it depends on your market on which motor you have +/- amongst all the models. Generally speaking after 2014 the motors are mostly N26s as BMW stopped producing the n20/n26 as much to slowly place the motor under the end of life, and roll out the b48. At the end of the day, the easiest way to tell is to read the emissions sticker on the car, or get underneath it and check for an additional catalytic converter. The N20 only has a muffler and resonator underneath after the downpipe, the N26 has a muffler, resonator, and an additional catalytic converter. https://www.n54tech.com/forums/showthread.php?t=20322 https://bmwtuning.co/bmw-n20-vs-n26-comparison/ https://www.edmunds.com/bmw/3-series/2013/review/ |
10-12-2020, 07:22 PM | #9 | |
Rep 20
10-12-2020, 11:07 PM | #10 | |
Rep 1,055
Please stop confusing the people |
10-13-2020, 08:39 AM | #11 | |
Rep 413
You can review the N26 details here: https://f30.bimmerpost.com/forums/at...9&d=1473767869
328ix 8AT Sport Line N26 | Navardi Custom Stage 2 93 | xHP Stage 3 | VRSF 5" HD FMIC | ER CP | ER Catted DP CTC | aFe Pro Dry S | MST Turbo Inlet | TMS Upper Air Intake Tube | 2nd Cat X | GFB DV+ |
sqwinny466.50 |
10-17-2020, 03:11 PM | #13 |
Rep 293
Want to chime in, grab BM3 and you're golden. Makes the car completely different and is faster than a stock 328. Stage 1 makes the car a nice daily. Stage 2 makes the car just barely slower than a 335i. Issues happen with pistons breaking on the 20i models with Stage 2, so keep that in mind. I've been stage 2 for 30k miles with zero issues
