08-24-2021, 03:40 PM | #23 | |
Rep 4,551
Drives: 2015 328d xDrive
08-25-2021, 09:31 AM | #24 |
Rep 688
Drives: 22 TR X3MC
Considering you have a 328D I would look into taking your car into the dealer since I'm pretty sure theres an open recall for the transfer case
2022 X3M Comp
2013 335i xDrive (Sold) |
08-25-2021, 10:04 AM | #25 |
Rep 4,551
Already did last year and the car checked out, but that was before the symptoms appeared. They're not bad enough to replicate regularly yet so I'm waiting till they're worse to go back again. I'm out of warranty and don't want to show up and pay a $165 diagnostic fee just for them to tell me they didn't notice any issues.
08-25-2021, 01:21 PM | #26 | |
Rep 688
Drives: 22 TR X3MC
2022 X3M Comp
08-25-2021, 06:01 PM | #27 |
Rep 4,551
Changed the fluid, flex disc, and output flange about 17k miles ago. Probably bought me some time but still feels like I'm driving a ticking time bomb. Once symptoms become more frequent I'll take it in.
10-16-2021, 02:34 PM | #28 |
Rep 4,551
Update: changed the transfer case fluid (again) at 70k, and did the rear diff fluid, transmission fluid/filter, and accessory belt and tensioner while I was at it. The car feels much smoother now. The transfer case stutter is still there occasionally (only when I'm WOT above 60mph) however It's much more subdued and it's not nearly as bad as it used to be. Definitely a large and noticeable improvement. Hopefully, I can just keep doing a fluid change every 2 years and never have to actually address it.
redbullfan356.00 |
10-16-2021, 11:54 PM | #29 |
Rep 125
To the OP. I had multiple coils fail from about 30K on and they didn't always have catastrophic failures that threw codes.
At least two times I had issues only under hard acceleration and full boost, but no codes. It took as much as a full month later for a fault that produced a code. Replaced that coil and the problem you describe went away until the next coil failure. I replaced them all and that situation hasn't occurred. With a stock tune the peak boost might occur in that range you're having the problem. Not suggesting shotgun repairs but coil failure is very common. |
imperfectluck425.00 |
10-17-2021, 02:53 AM | #30 | |
Rep 419
10-22-2022, 08:41 PM | #31 |
Rep 1
I have the same stutter issue on hard acceleration. Only when I get aggressive with the throttle. 2015 6 speed, intake, charge pipe, intercooler, muffler delete. Replaced plugs and it got better. Found a missing bolt on charge pipe sensor and replaced it and again made it better but still stutters when I get hard on the throttle but 2nd gear is the least affected. I'm going to keep looking for boost leaks but at a loss of the main issue. please help.
10-23-2022, 04:47 PM | #32 | |
Rep 7,602
10-24-2022, 01:48 PM | #33 | |
Rep 529
2013 F30 335i xDrive M-Sport 6MT (FBO/BM3 custom tune by HCP, 91 oct, 550i clutch, xDelete)
11-08-2022, 04:19 PM | #34 |
Rep 6
Did anyoen get a resolution to this?
I see this issue on all of the forums and I'm having the same issue. I have replaced the plugs and coils and ran a smoke test and fixed two leaks I found. I suspect that its either fuel pressure or an injector but before I start going down the expensive path of replacing injectors or high pressure fuel pump I wanted to see if anyone had any success with other updates. My car: 2011 335xi m-sport 6MT MHD Updated cp, intake, dp, dinen coils, plugs, GFB DV |
11-08-2022, 06:00 PM | #35 | |
Rep 7,602
