11-18-2020, 09:25 AM | #243 | ||
Rep 869
11-18-2020, 09:46 AM | #244 | |
E36M3 2/5 garage queen X3 3.0si
Rep 40
I feel like its in my head that the wheel gets somewhat warm, but I just don't know. I feel my brothers F80 wheel and it is very warm. You would think since the light is working that it should heat the wheel either way. any help would be much appreciated. this is what i coded FEM_BODY 3140 PFLinSteeringWheel CODDT_BYTE_00_SZL_LIN = LHZ_aktiv LIN_VARIANTE_LRE = lre_tlc_lhz LIN_VARIANTE_SZL = szl_4Band LRE_Verbaut = aktiv |
11-18-2020, 09:52 AM | #245 | ||
Rep 869
11-18-2020, 09:54 AM | #246 |
Rep 40
11-18-2020, 09:55 AM | #247 |
Rep 869
Yes that entire thing has been known to fail and you gotta get a new one.
11-18-2020, 09:58 AM | #248 |
Rep 40
11-18-2020, 11:30 AM | #249 |
Rep 869
11-20-2020, 12:46 PM | #250 | |
Rep 40
11-20-2020, 01:13 PM | #251 | |
Rep 40
BIG THANKS TO HAWKO!!! Last edited by 320if30; 11-20-2020 at 01:19 PM.. |
01-24-2021, 07:58 AM | #252 |
Rep 2
How to connect to LIN
Could someone help me with connecting the Steering Wheel Electronics Module to the LIN?
I found one with 4 connectors on the wiring harness, and one that connects to the module itself. Below pictures from the wiring harness and the connector to the controls on my steering wheel. Doughboy wrote about this in post 140, but I didn’t understand. For Power I used the solution of david51. Last edited by GreyF31; 01-24-2021 at 08:22 AM.. Reason: Asking not only Doughboy |
12-29-2021, 06:54 AM | #253 | |
Rep 4
01-16-2022, 09:25 PM | #254 |
Rep 15
01-17-2022, 02:34 AM | #255 |
Rep 3
Hello, I have a question, on my 2017 f30 I retrofitted a heated m sport steering wheel, when I try to plug in the Switch for turning on the heating into A83*5B on the SZL it has no pins in only the hole is present...
The car does not have LDW or lane asist or radar cruise control. New gear change pedals work tho. |
01-17-2022, 12:27 PM | #256 | |
Rep 15
01-24-2022, 10:28 AM | #257 |
Rep 3
Heated Steering Wheel Button
Hi, my F22 has lane departure warning and I plan to retrofit the heated steering wheel function.
I wanted to install a generic button (OEM is too expensive imo). As I understand the original button has 3 pins: LED Power, button power and ground. Does anyone know if I need a actual button (just a electrical signal when pressed) or a "switch" button? |
01-24-2022, 10:42 AM | #258 | |
Rep 8,970
01-26-2022, 02:51 AM | #259 | |
Rep 18
My SZL is not prepared for heated steering wheels. According to the instructions, the power pins were blown, I used the pins in the airbag plug, the power supply of the module is, however, the coding is done, and the heating does not work. Maybe there is another solution? The entire heated steering wheel assembly is operational. Because it currently works for me on SZL with F33, but I have no rear wiper and FLA function. |
01-26-2022, 07:24 AM | #260 | |
Rep 817
Drives: bmw M3 F80
you can buy a szl model F30 it is the same as F31 |
01-29-2022, 09:35 AM | #262 |
Rep 17
Hi could anyone say if 9253751 szl would support heated steering wheel or is it a new one needed ?
Think I've found answer and it's no Last edited by Ally18; 01-29-2022 at 09:47 AM.. |
01-29-2022, 09:46 PM | #263 |
Rep 817
Drives: bmw M3 F80
Yes you are right here are the compatible models https://bimmercat.com/bmw/fr/parts/i...1146/appliance you have to check and tick according to the options you have to have the right reference https://bimmercat.com/bmw/fr/search/...0d/ECE/61_5559 |
01-30-2022, 02:21 AM | #264 | |
Rep 18
Nevertheless to find SZL to F31 / F20 / F25 it is a problem |
Tags |
f30, heated, heating, steering, wheel |
