BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Blow Off Valve F30 320i B48
proTUNING Freaks
      12-25-2017, 12:42 PM   #1
joanjgm
joanjgm's Avatar
Spain
Drives: 320i
Hi there,
Does anyone know what kind of BOV I need in order to get that swish sound on my 320i with B48 engine? I know I probably won't get any better performance or improvement, I just think the sound is really cool
Any suggestions?
      12-25-2017, 01:09 PM   #2
Rob340i
Sergeant First Class
Drives: 340i M Sport
I just asked nearly the same question several days ago. You will find the answer here.
http://f30.bimmerpost.com/forums/sho....php?t=1450871
Make sure you search a topic before posting.
-Rob
      04-13-2022, 11:03 AM   #3
jtalweezy
Drives: 2017 BMW 330i xdrive (B46)
to be fair, if he searched B48 BOV your post may not have made it to the list of threads.
to the OP:
Because the B series engine use an electronic wastegate, there likely wont be any BOV options for quite a while. What some guys are doing is coding out the EWG (disabling it) which with something like BM3 you can do. Then they are adding standard BOV valves to the charge side of the turbo. It aint cheap.
https://bigboostturbo.com/products/n...-off-valve-kit
2017 BMW 330ix MSport Estoril Blue - B46, ER Catless DP, ER Chargepipe, FTP Intake Charge Pipe, BMS Cone Intake, BMS OilCC, Bm3 Stage 2. FI Exhaust, xHP Stage 3 OTS Transmission tune. CSFRace heat exchanger. Performance M Brake kit. AFE Carbon Fiber D.A.S.
https://www.instagram.com/bfourtysick/
320i, b48, blow off valve, f30
