01-07-2019, 04:36 PM | #1 |
Rep 59
Calibrating your Torque Wrench DIY
Hello,
If you think your torque wrench is out of tune or would like to check it... Here's how. Procedure is good for all, but adjustment is slightly different depending on the different models and brand... |
01-07-2019, 06:47 PM | #2 |
Monobloc
332
Rep 447
Drives: '02 M Coupe - '19 F31 330ix
Thank you for sharing that DIY calibration video. I have a few torque wrenches (bought new) that have not been calibrated, but then again they aren't used all that often. They are never dropped, , banged, or loaned out as well!
-2023 Honda Odyssey Elite - Sonic Gray Pearl / Black
-2019 F31 330ix Individual - Champagne Quartz / Coral Red (M-sport, Exec, Premium, Track) -2004 Honda CRV AWD - Silver / Black -2002 S54 M Coupé - Steel Gray / Dark Gray/Black |
01-07-2019, 07:06 PM | #3 |
Rep 59
Glad it help.
Normally, when new, they should be calibrated. Sometimes, they come with a calibration certificate. In which there is 2 or more point of calibration with the error or offset (accuracy). |
01-08-2019, 01:07 PM | #4 |
Rep 6
I agree about calibrating. I have a couple I need to check. I prefer this guy's method using an inexpensive luggage scale which I stumbled across two days ago. I think it will be more accurate. I just ordered a scale from Amazon.
01-08-2019, 06:03 PM | #5 |
BMW CCA #257
75
Rep 190
Hint .... make sure when you store your Torque Wrench you turn down the setting to 0. This will help preserve it's life and keep it calibrated.
2014 F31 328 xDrive Touring
2020 G20 330 xDrive Sedan 2023 G01 X3 xDrive BMW CCA # 257 |
Digital_83262.00 |
01-08-2019, 07:22 PM | #6 |
Rep 2,387
Here's something I learned while researching for a new torque wrench. Click-type torque wrenches are inaccurate at the extremes, particularly at the low end, on the order of 20% of the range. So for example, if the range is 25-250ft/lb, take 20% of the difference (225). Your wrench is accurate starting at 45 ft/lb. This is why you need 2 torque wrenches, one for light stuff and one for higher torque values.
2016 340i XDrive, EBII/black, 6 MT, M Sport, Track Handling, Cold Weather, Tech, Lighting, Driver Assistance Plus.
2012 Z4 35i, ED 2/24/2012, Melbourne Red Metallic, Black Leather, Carbon Trim, 6MT, M Sport, CW, PP, PS, NAV, CA. |
Digital_83262.00 |
adjusting, adjustment, calibrate, calibrating, diy, how to, torque, torque wrench, wrench |
