07-02-2019, 12:33 PM | #67 | |
Rep 500
Drives: BMW 330e F30 M-sport
Yes, but I've opted out of insulating the entire floor, it's just too much work. What I've come to realize is that the roads around where I live are REALLY rough, in order to withstand both the climate and the high levels of traffic (I live just outside Oslo in Norway). Recently I drove on some mountain roads that were built for way less traffic and it was almost silent in comparison. I actually measured the dB level, and the sound level at 110km/t on those mountain roads was the same as at 60km/t on my local roads. So the road surface has a big impact on the sound level. And the worst roads (which apparently is what I have around me) is probably really difficult to insulate against.
Thorbjorn
16 BMW F30 330e M-sport Bootmod3 Stage2 / BMS Intake / RM Motors high flow catted downpipe & custom exhaust / BBS CH 19" / H&R Sport springs |
07-07-2019, 04:14 AM | #68 |
Rep 500
Turns out the rear tire walls are only barely touching the inner lining, so no need to roll the fenders. - It also rubs very rarely, so will see if it wears off, or will consider going down to 255 in the rears.
Thorbjorn
08-08-2019, 01:17 AM | #70 |
Rep 1
Your car is gorgeous!!!!
I have the same car /colour combo but I love your mods! It might be a silly question, with the mods, would BMW (if anything went wrong) give you a 'goodwill' gesture for repairs or wouldn't you bother going to them? I have had a few issues with mine and its currently there for a gearbox shunting/juddering issue. Thanks |
hybris204.50 |
08-08-2019, 12:05 PM | #71 | |
Rep 500
If I had a problem that were clearly caused by my own modifications, I would not try to get that fixed under warranty. I would likely still go to BMW to get it fixed, as I have a very good relationship with my local dealership. If I had problems that were not directly related to my mods, I would not expect problems at the dealership - but your experience may be different based on your relationship to the dealership and how mod friendly the dealer is.
Thorbjorn
08-11-2019, 12:15 PM | #73 |
Rep 500
Couple of insta pics from this summer:
Thorbjorn
09-20-2019, 04:41 AM | #74 |
Rep 500
Couple of updates:
I had some rubbing issues in the back, so I replaced my rear wheels, going down from 265/35R19 to 255/35R19 - which means I can now at least get a finger between the tire and the fender, and now I'm all good. Went with Falken FK510. Second, I've ordered a tiny (8 litre), sealed subwoofer box that I'll stuff a high power 8" driver (Ground Zero GZUW8SQX 300W 2x2ohm RMS and weighs in at 4.5kg) into, and also add a high power amp to run it. Hopefully this will add a bit of meat to the low end. I'll place it in the area on the left side of the trunk (see picture), so in theory it will steal almost nothing of the available luggage space.
Thorbjorn
09-24-2019, 11:22 AM | #75 |
Rep 500
Box arrived! Now I just need ..everything else.
Plan to be done with it all next week.
Thorbjorn
09-24-2019, 03:01 PM | #76 |
Rep 864
Looks good, unfortunately my F31 doesn't have that area in the side of the boot that the F30 does. If you do it all yourself, can you post a guide of how you connect it all up? Both to the headunit and to the battery would be awesome.
09-25-2019, 11:04 AM | #77 | |
Rep 500
Thorbjorn
10-03-2019, 01:40 PM | #78 |
Rep 500
Sub in place! Discret and perfect fitment, couldn't be much better if it was custom made. The Helix M One 600W@1ohm Class D amplifier (a different one than I originally planned) is hidden under the floor right next to the original amp, keeping the 8" woofer in check.
It's small, so it's not a wall of sound, but tight and clean bass that supplements the HK and adds both punch and depth. I now have negative EQ (2 or 3 negative steps) at 100hz to give the HK speakers more breathing room, and fill up that void with the new sub. Works like a charm! As an intentional added bonus, almost 100% of the luggage space is still available, so I can keep the sub in when the whole family is on trips with the trunk filled with bags and stuff.
Thorbjorn
16 BMW F30 330e M-sport Bootmod3 Stage2 / BMS Intake / RM Motors high flow catted downpipe & custom exhaust / BBS CH 19" / H&R Sport springs Last edited by hybris; 10-03-2019 at 01:46 PM.. |
02-09-2020, 10:36 AM | #79 |
Rep 500
New winter setup: Stumbled across a set of powder coated 351 wheels (originally from F10). Not used after they were powder coated, so they're in perfect condition. Color is dark grey metallic, almost the same color as the car (Mineral grey). Love the look!
The weather here is horrible at the moment, so sorry for less than great pictures.
Thorbjorn
02-09-2020, 02:20 PM | #81 |
Rep 500
Thanks! No, the spec is reasonably similar to what typically fits on F30.
They're 19x8.5" ET33 front and 19x9" ET44 rear.
Thorbjorn
02-09-2020, 02:32 PM | #82 | |
Rep 584
On a different note. Are you running a carless down pipe on your 330e? Hopefully going with mg flasher this week when my WiFi obd adapter arrives. Curious about emissions. Cars are tested very 2 years in Ireland. Not sure if it's worth fitting a catless DP or even a performance cat version |
02-09-2020, 02:53 PM | #83 | |
Rep 500
Thorbjorn
02-09-2020, 03:07 PM | #84 |
Rep 584
02-09-2020, 05:34 PM | #85 |
Rep 584
02-10-2020, 10:31 AM | #86 |
Rep 500
Didn't do it myself, but my understanding is that it is fairly easy to do.
Thorbjorn
02-14-2020, 10:47 AM | #87 |
Rep 500
Really happy both with the wheels and the stance now
Thorbjorn
02-20-2020, 02:37 AM | #88 |
Rep 500
Finally got some nice burbles working too. I like how it's a pretty deep sound (if you listen on headphones and not just your laptop speakers) but at the same time raspy/throathy.
Also happy with the amount of burbles. Not too crazy but pretty consistent
Thorbjorn
330e, 330e tuning, b48, bm3, bms, f30, mineral gray f30 |
