10-20-2020, 01:49 AM | #23 |
@_sunbish
282
Rep 609
Anyone run this with BM3 and the max cooling? For everyone who’s installed this part, does it keep the oil temps from rising up to ~250 degrees after some WOT pulls?
10-20-2020, 11:20 AM | #24 |
Rep 876
BMW DIY Guy3068.50 |
10-20-2020, 12:18 PM | #25 |
Rep 965
Drives: 2016 F36 435x MSport
Anyone run some blackstone tests on a good oci? Just wondering if you are seeing more moisture in the oil since it is running cooler.
10-20-2020, 05:55 PM | #26 |
Rep 876
225 is more than hot enough to not see any increased moisture, from what I’ve read. I use only BMW oil, and change at 2x recommended intervals - no oil testing. Most other BMW engines using this same oil run cooler avg oil temps than the 250 I was seeing in my N55.
10-20-2020, 09:20 PM | #27 | |
Rep 1,934
10-20-2020, 10:30 PM | #28 |
Rep 7,597
10-21-2020, 08:38 AM | #29 |
Rep 876
10-21-2020, 09:12 AM | #30 |
Rep 965
*math police BEEWOOO BEEE WOOO*
Then it should say "1/2 the recommended intervals" why you gotta scare Logicoeur like that
2010 Mazda RX8 - Sold (11/17)
2016 BMW 435xi GC - Current |
Pussiwillow521.00 |
10-21-2020, 11:30 AM | #32 |
Rep 237
I run it with a lowered coolant target in MHD. I think it's set to 85c iirc, 'sport cooling' option. In hot weather the oil temp does not go above 100c though the actual coolant target changes based on mode. In sport+/DSC off, it goes from 80-85c ish, and in comfort it's around 95. I will likely raise the coolant target to stock for winter to get a higher amount of heat in the bay as as put the foam and engine cover back on top.
So with the thermostat, lower coolant target, and removal of the stock cat the engine bay has the best thermals its going to reasonably get. |
10-21-2020, 11:38 AM | #33 |
Rep 1,934
I'm an engineer so yeah I was scared at the thought of 2x
10-21-2020, 02:12 PM | #34 | |
Rep 7,597
10-21-2020, 06:09 PM | #35 |
Rep 876
10-21-2020, 06:38 PM | #38 |
Rep 1,148
10-22-2020, 10:02 AM | #39 | |
Rep 237
10-31-2020, 08:06 PM | #40 |
Rep 3,016
Drives: 2019 M2 Competition
Sometimes its the attention to the smallest details that makes the biggest statement!
Mosselman Turbo Systems have upgraded the reverse torx bolts, reusing the oem, to 10mm titanium bolts! Their oil thermostat upgrade was already really awesome in look and function, but this just tops it off! Well done!
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
10-31-2020, 10:06 PM | #41 |
Rep 876
Yeah, I got the Ti bolts, they’re visible in the pic I posted. Very subtle, oem+.
10-31-2020, 10:57 PM | #42 |
Rep 1,288
Actually a great video... I've been on the fence changing my oil once every year since I drive less than a thousand miles a year... knowing oil is key (especially on BMWs').. I change it just for the fact of it's cheap insurance...
01-14-2021, 05:54 AM | #43 |
Rep 1,945
Happy to see these getting used!
I believe SD garage is their premier dealer here in US. |
BMW DIY Guy3068.50 -Eidos489.50 |
