BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > OFFICIAL Slammed/Stanced (F30/F32) Thread
      12-12-2020, 01:18 PM   #1805
Galip1993
Drives: dodge challenger srt 392
Hello everybody, I have a quick question regarding Wheel/tire size. I don’t have much knowledge regarding f30 wheels/tire size fitments.
Is this size,
Wheel size: 19x8.5 ET 35 (front). Tire size: 225/40/19.
Wheel size: 19x9.5 ET 35 (rear). Tire size: 255/35/19.
too big of a setup for a F30 with h&r sport lowering springs? If anybody has a similar setup, let me know.
      12-14-2020, 07:33 AM   #1806
TheFanatic
TheFanatic's Avatar
Drives: BMW 340i
Is this size,
You'll be fine
      12-14-2020, 11:45 AM   #1807
j2nicee
j2nicee's Avatar
55
Drives: 2009 E92
Originally Posted by Canadared View Post
I plan on getting wheels rebuilt, 19x9.5 +30, 19x10.5 +40 with some camber. Rub yay or nay?
Will all depend on tires and how low you go. I was going to go with a similar set up but I was told I may run into inner clearance so I dropped down to a 9/10 set up. The fenders on these cars are very weak apparently so keep that in mind.
      12-14-2020, 01:26 PM   #1808
Canadared
Drives: 2012 BMW 335i F30
Oh I know, I ran 19x9 +35 fronts with 8mm spacers and jacked up my fender pretty good backing out of my drive way. Mind you it was hella low so it comes with the territory. Gonna get Millway camber plates to help out
      12-15-2020, 01:53 AM   #1809
Waltabeast
Drives: 2016 435i M sport
19x9.5 +33
19x10.5 +38
Sigge155.50
kern4174446.50
      12-29-2020, 08:08 PM   #1810
justanthony1
justanthony1's Avatar
Drives: 2013 335i
Originally Posted by himynameskevin View Post
Been a minute but figured I'd check back in
Damn this is hot! Share specs!!
      12-30-2020, 03:59 PM   #1811
Arf01
Drives: Bmw 330d RWD 2014
Hi all,
I have 405m replicas (i was told they were OEM but recently found out otherwise).
Current setup (staggered)
Fronts - 245/30/20 - 8.5j
Rears - 265/30/20 - 9.5j
I've managed to crack one of the font rims (welded a couple of times but keeps cracking) and there are no offsets stamped in any wheel. I have managed to find simailr rims but needed to know my current setup as I'm after the same look.
Any ideas what my current setup is ? Pics below:
Car is standard stock m sport suspension
No idea if they are 40/45 or 35/38 or something completely different.
      12-31-2020, 06:03 PM   #1812
iron_mike_
Drives: F30 328i
Love this. Care to share your specs? what rims are these?
      01-04-2021, 10:27 AM   #1813
Grecg
Drives: 2016 328i
Apex arc 8
19x9 et 28 245/35
19x9.5 et 33 265/35
Appreciate 8
      01-05-2021, 08:03 AM   #1814
j2nicee
j2nicee's Avatar
55
Drives: 2009 E92
Clean, gives a little RS-II vibe.
      01-05-2021, 06:33 PM   #1815
Spanky_F30
Spanky_F30's Avatar
Drives: 2013 BMW 328i M-Sport
2013 BMW 328i  [0.00]
Current side pic
kern4174446.50
j2nicee55.00
M3EW221.00
      01-07-2021, 12:49 PM   #1816
jackthew
Drives: 2015 335i FBO
Quick question
I am looking at 18x8.5 ET 35 fronts, and 18x9.5 ET 35 rears for my car, with 255/40 all around.
Is ET35 too little for the rear?
I will be installing BR Racing BR Series coils very soon after getting the wheels.
      01-08-2021, 09:31 AM   #1817
tomppa
Belgium
Drives: 6
Originally Posted by Dippydo View Post
No. I had 42 in the rear on a 10.5 and with the KW I rubbed at about 10 oclock on the rear fender. The kws are too soft. Even at the highest point and I turned rebound to the hardest part it still rubbed. My H&R coils before did not though, but they were a stiffer ride. I went and had my hubs shaved to be a 44 offset and no more rubbing.
Damn, can you just fix your hubs to lathe and shave 2mm off!?
How do you know it won't fail on high speed corner at 220 km/h?
Then, could you do the same for wheels too?
      01-08-2021, 02:50 PM   #1818
kern417
Cheapskate
4447
Drives: 2018 440i |2016 340i | 2010 X5
Originally Posted by jackthew View Post
Quick question
It's way more stretch than you need to fill out the fenders. You may need spacers for good fitment, but then the wheels will poke.
Youtube/Instagram/TikTok: @kern417
      01-14-2021, 04:19 PM   #1819
Grecg
Drives: 2016 328i
Thanks 🙏🏽 RS II's are some of my favorites!
      01-19-2021, 02:55 PM   #1820
PKEF32
Drives: BMW 435i
My new Vertini config
      01-20-2021, 04:22 PM   #1821
boiet671
Hafa Adai
Drives: bmw 535xi 328i xdrive
Hi! Got the same setup, 19x9.5 et35 255/35/19 square and my front wheels are touching the strut! Are you running any spacers? I’m on bcbr coilovers. Any info on this would help! Nice ride too!
Originally Posted by Ih8usrnms View Post
the front wheel specs are 19x9.5 et35 tires are 245/30/19 i believe. the rears are 19x10.5 265/30/19 not sure of the offset.
      01-22-2021, 10:57 PM   #1822
M3EW
M3EW's Avatar
Drives: F80 M3
Want new wheels already
@cheungkyf80
Appreciate 6
j2nicee55.00
Grecg55.50
kern4174446.50
saga boy299.50
Fate90.00
      01-23-2021, 08:37 AM   #1823
j2nicee
j2nicee's Avatar
55
Drives: 2009 E92
Stupid clean man!
Whats you diffuser set up? 3 piece? Looking for a replacement one right now.
      01-23-2021, 11:01 AM   #1824
M3EW
M3EW's Avatar
Drives: F80 M3
Stupid clean man!
https://www.ebay.com/itm/Rear-Bumper....m46890.l49292
https://www.ebay.com/itm/AK-Style-Ca....m46890.l49292
Here you go man. Wish it was a three piece lol. I had to do a lot of research before hand to see if this would work since, from what I see, I'm the only one that has this setup. I bought the PSM style rear skirt extensions from China and then the AK diffuser from Taiwan. The rear extensions were an easy install, but the diffuser took an hour or two cuz it's hard af to fit. Total price I paid was about $700 shipped+tax. Also the wait time took about 6 weeks for the pieces come in since it's overseas. Hope this helps
@cheungkyf80
j2nicee55.00
      01-25-2021, 01:12 PM   #1825
RobF30
Drives: 2014 BMW 328i Sportline
Originally Posted by jeremyuhh View Post
Cut springs
Are these M4 rims?
      01-26-2021, 10:06 AM   #1826
j2nicee
j2nicee's Avatar
55
Drives: 2009 E92
I think 18/19 are the best sizes for the F30 chassis. 17s look a little too small and 20s are just a tad big.
Flagnn7.50
aggressive, f30, low, slammed, stance
