10-04-2021, 02:47 AM | #1 |
Rep 13
NBT gone
Hi guys
I tried to activate the AppleCarPlay. And i take it fsc codes from hutool 2.6 . I don't know why but after add fsc codes screen was availble but navigation was grey, i mean i couldn't open the navigation. So after this i try to open navigation back. Then i upload car's stock nbt file from Autel. After then screen gone and no signal appear. I guess i really fucked up.[IMG][/IMG] [IMG][/IMG] [IMG][IMG][IMG][/IMG][/IMG][/IMG] |
10-04-2021, 06:15 AM | #2 |
New BMW owner
139
Rep 621
Try assigning the cafd again.
If that doesn’t work, I’d try to flash it. |
10-04-2021, 06:57 AM | #4 |
Rep 1,976
Drives: 2020 G20 320i M Sport
The SWFL files are corrupt hence the FFFFF on the file names.
You need to flash it with E-sys to restore those files. Looking at the hardware ID, this is an ID4 unit so it looks like you tried to region change it or something.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
10-05-2021, 06:06 AM | #5 |
Rep 13
I tried to inject apple car play but i guess i did something wrong. I tried to flash nbt but nothing change actually. I gave it to an electrician and i guess he fix it with bench equipment.
10-22-2021, 04:26 PM | #6 |
Rep 228
Drives: 2022 G20 330E
you have to flash your EVO because SWFL's are F*cked up, that's what you get when you use cracked software on your expensive units.
| MGU Patching/Virginizing | ConnectedDrive activation for US cars in EU (Only MGU/ATM2) | Feature Installer codes | Map Updates | CarPlay activations. | NBT EVO GPS Connector installs. | NBT EVO repairs | Remote BMW Coding |
