05-28-2020, 08:58 AM | #1 |
Rep 47
Tuned N20 DV or BOV upgrade
Hi, so I have a couple of mods installed on my F31 this includes a CTS BOV, I wasn’t really looking for sound but mostly for rialibility since I’m running on higher boost with stock turbo. My JB4+ is set on map3 with 18 psi boost which is really great and looking forward on upgrading to BM3 while retaining the JB4 for the meth kit. Sometimes when flooring boost raises to 20.9 so it’s not always stable at 18, I’m thinking this could be a battle between the piggyback JB4 messing with the ECU. Car feels great way better than before so I can’t really say that the CTS BOV is a negative upgrade since all mods were done at the same time. Besides the loud ppshhhh sound in between shifts or when letting go of the gas pedal, I don’t feel any power or boost loss. CTS is great quality well built only issue is that they don’t supply in their kit a vaccum boost tap for the intake so be aware before installing.
Since my personality isn’t showing off, the ppsshhh sound gets to me sometimes LOL I don’t really care that much I can live with it. Now here’s my question towards experienced techs, am I really having power or boost loss with the BOV, If so would you kindly explain how? And would replacing the CTS BOV by let's say GFB DV+ make any difference in power? Thanks |
05-28-2020, 01:19 PM | #2 |
Rep 4,358
i am not an experienced tech nor do i have any yet.
i've been meaning to upgrade the dv at some point but prefer a complete unit swap and something better than just upgraded internals. i have been waiting for Turbosmart to come out with one for N20, they replied that they might in the future but i'm not holding my breath. "if it ain't broke, don't fix it"...if you're happy with CTS Turbo blow-off, i'd just leave it. the only way to know if a GFB DV+ is better(or worse) is getting one and comparing them. i don't think it's worth the trouble. |
05-28-2020, 03:30 PM | #3 |
Rep 47
Makes good sense, the CTS one is a complete unit versus the GFB that’s more like a add on spacer with small hardware. Let’s see maybe some expert will catch this and give his feedback.
05-28-2020, 04:40 PM | #4 |
Rep 4,358
i believe this (n20)gfb dv+ thread had a lot of debate within. most of it about flutter or compressor surge(from backflow to the turbo), indicated by the unique sound the GFB DV+ usually makes especially before break in.
https://f30.bimmerpost.com/forums/sh....php?t=1482708 the gfb dv+ will maintain boost longer and dump it slower due to a stronger spring and single exit. i believe during shifts is where it's benefit lies. if the CTS is dumping all of it between shifts, i suppose it could be detrimental on a stock car, but since you're are high boost, maybe not so much? idk. maybe you can "take one for the team" and get the GFB DV+ for an objective comparison. TIA, j/k |
05-29-2020, 08:23 AM | #5 |
Rep 47
Interesting, from my experience with the CTS doesn’t feel like it’s dumping all the boost in between shifts. Actually I don’t feel any turbo lag, I guess it all depends how long you let go of the gas pedal. I only say this because I hear the dumping pshhh sound only when letting go of the pedal. It stops as soon as you press the pedal so this probably means that it doesn’t dump all the pressure boost.
alohasurftoad3112.00 |
05-29-2020, 12:30 PM | #6 | |
Rep 4,358
08-06-2020, 03:32 PM | #7 | |
Rep 40
08-06-2020, 06:53 PM | #8 | |
Rep 4,358
edit added: i went to several bmw parts sites and found the oem dv part number for the m2(n55), x4(m40i) to be 11-657-601-058, which the turbosmart vr11 replaces. unfortunately the N20 oem dv part number is 11-657-609-210. i have seen bmw list different part numbers for the same item before* but i'd be hesitant about this one since they are very different engines. *an example of this are n20/n55 intercoolers. they are the same part but have different numbers for n20 vs n55. i've also seen this with suspension dampers and springs, same parts with different part numbers for different cars. it's quite annoying and confusing that they do this and they often confuse themselves because their own parts guys are unaware of this. Last edited by alohasurftoad; 08-08-2020 at 10:00 AM.. |
08-09-2020, 05:38 AM | #9 |
Rep 132
Drives: M4 6 Spd, X6 G06 30d, G22 420i
I've installed the GFB DV+ and I can tell you now that my car feels much more responsive. I can definitely feel the boost holding between gears too.
~ Sapphire Black M4 G82 Manual
~ Mineral White Metallic X6 G06 30d M Sport ~ Sapphire Black 420i G22 M Sport #savethemanuals |
09-10-2020, 09:00 PM | #10 | ||||
Rep 40
2015 328i N20 - Custom ACN91 tune by Navardi Tuned, VRSF catless downpipe, FTP Motorsport charge and TIC pipes, Turner Motorsports turbo inlet and upper intake pipe paired with modified stock intake box, Active Autowerke FMIC, AWE quad exhaust and mid pipe, Airlift 3P air suspension, Megan Racing rear suspension arms, Volk Racing TE37 SL, other shit...
09-17-2020, 08:35 AM | #11 |
Rep 1,066
Any update with this? I'm looking to do the same but was holding off to know if the VR11 was a straight bolt-on affair compared to the GFB+.
10-01-2020, 07:47 AM | #12 |
Rep 40
I haven't gotten around to it yet. The VR11 is on my nightstand haha. I'll do the install when I replace my front bumper, probably in a week or two
04-23-2021, 11:27 AM | #14 |
Rep 1,066
royjovero did you end up installing the VR11 onto your N20? honestly curious as I'm writing a post to try and get stickied for information with options for the n20/n26 crowd to avoid the same questions every 2 weeks
06-04-2021, 12:01 PM | #15 |
Rep 40
Hey all, sorry for not updating. I still haven't installed the Turbosmart. I'm lazy and will be moving in a couple of weeks. I'll have much more free time after I move and I plan on finally installing it by the end of July
10-23-2021, 11:05 AM | #17 |
Rep 551
10-23-2021, 11:10 AM | #18 |
Rep 40
I can't confirm whether or not the Turbosmart will work. I tried but it won't install like the DV+. It might work with removing the turbo but I didn't want to go down that rabbit hole
10-23-2021, 08:20 PM | #19 |
Rep 6
10-29-2021, 08:50 PM | #20 |
Rep 6
10-31-2021, 04:38 PM | #21 |
Rep 6
Contacted Turbosmart - they started they haven't tested the n20/n26. Went ahead and purchased the VR11. I'll report back if it fits.
11-10-2021, 03:30 AM | #22 |
Rep 6
Putting this to rest for anybody else that searches and finds this thread -
The VR11 will plug into the harness. The wire gets in the way of the hot pipe off the turbo. You can attempt to reclock it but that puts the bov vents facing into the engine and the turbo casting. The bov would also require clearancing as it impacts the head. In short no it doesn't fit - don't try it.... |
