09-23-2020, 08:23 PM | #1 |
Rep 874
Drives: F32 428i Xdrive
Wanting to max power, expected gains?
So as title suggest, I'd like to just see what other's experience is with my shared platform and what the highest/expected gains are
I drive a 2014 428i xdrive with an n26 If I were to go full bolt on, say max out everything I could with out touching internals, new turbo, the lot What am I looking to get power wise? And on another note, what's my mpg go down to?
09-23-2020, 10:36 PM | #3 |
Rep 874
Wow that's not a lot. I guess I'm expecting a little more from what I've seen
09-24-2020, 07:17 AM | #5 |
Rep 15,962
No matter what you do there's only so much you're going to get out of an N20/26. If it was only 170HP bone stock like a Toyota Corolla there would be a lot of room for improvement, but it's not.
09-24-2020, 09:14 AM | #6 |
Rep 874
Yeah that makes sense. I've got 93 luckily in my town as well as my state for the most part
09-24-2020, 09:16 AM | #7 |
Rep 874
Yeah it makes sense for sure, I was just confused as to what B005t did to his cause I just saw thicf30's vid on the dyno
09-24-2020, 09:32 AM | #8 |
Rep 190,120
OTS Bootmod3 maps
N20 (low-compression 28i) Stage 1 91 octane: 16%HP / 20%TQ Stage 1 93 octane: 18%HP / 22%TQ Stage 2 91 octane: 20%HP / 24%TQ Stage 2 93 octane: 22%HP / 25%TQ Stage 1 E30 octane: 21%HP / 24%TQ Stage 2 E30 octane: 25%HP / 27%TQ N20 (PWG 20i) Stage 1 91 octane: up to 24%HP / up to 38%TQ Stage 1 93 octane: up to 26%HP / up to 38%TQ Stage 2 91 octane: up to 28%HP / up to 42%TQ Stage 2 93 octane: up to 30%HP / up to 42%TQ Stage 2 E30 octane: up to 33%HP / up to 45%TQ Stage 2 racegas: up to 33%HP / 45%TQ N20 (EWG 20i) Stage 1 91 octane: 48%HP / 54%TQ Stage 1 93 octane: 52%HP / 56%TQ Stage 2 91 octane: 54%HP / 58%TQ Stage 2 93 octane: 56%HP / 60%TQ Custom map will net you another 10-20% depending on how aggressive you want to go. Pure Turbo stage 2
09-24-2020, 09:35 AM | #9 | |
Rep 874
I'm a little confused though, what is PWG and EWG? And I have an n26, would that lower the top end by a significant margin?
09-24-2020, 09:37 AM | #10 | |
Rep 190,120
EWG is electronic (newer models)
djacinto343.00 |
09-24-2020, 09:39 AM | #11 |
Rep 874
Got it ok, that's a little more what I was expecting. So what does it take to go from 300 to 382?
09-24-2020, 10:29 AM | #12 | |
Rep 1,051
FBO: Catless downpipe Axle back exhaust GFB+ Turbo inlet Intake Chargepipe Turbo to intercooler pipe Intercooler (Wagner comp 2, Evolution raceworks, ATM, CSF, turner Motorsport) Tune (bm3, JB4) custom tune. Good luck.
MY13: TTE400 Stage 2 turbo, Spec Single Mass flywheel + Stage 3+ Clutch, FTP V2 Turbo Inlet, Evolution Racewerks Charge pipe + Boost pipe + Intercooler, Turbosmart Recirculating Diverter Valve, aFE grill scoop + aFE Magnum Force Cold Air Intake, B58 coil retrofit, eBay Downpipe, Active Autowerke muffler, DW400 LPFP, B58TU HPFP, M5 s63TU injectors, Bimmermilvs, e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block
djacinto343.00 |
09-24-2020, 10:32 AM | #13 | ||
Rep 874
09-24-2020, 10:40 AM | #14 |
Rep 1,051
Something to be aware of is when you aim to go further than 350whp, it's advised to change rods and bolts minimum as the rods and bolts are known to let get above that range. It's the nature of the motor having full torque available below 2500 rpm.
djacinto343.00 |
