06-12-2020, 09:32 PM | #1 |
Rep 41
Car wont engage in Sport/Sport+
Car wont engage in Sport/Sport+...
Or it will engage awhile and goes back to comfort after 10 seconds... I just got a custom tune from BM3 from a tuner... Cleared fault codes through Carly, no change... Any idea what's wrong? Update: there's a "Chassis. Drive Moderately" message now...
335i F30 PWG, PS2, XDI-35, ER DP, CSF FMIC, MST AI, BM3, Snow Perf WMI
06-12-2020, 09:52 PM | #2 |
Rep 820
Drives: Bmw 335i f30 N55 ( sold)
Bm3 is the problem.. go mhd 😂😂 no honestly idk the answer too this.
2012 bmw 335i sedan
VRSF catless DP VRSF 5? HD IC Stock intake(had open before and was sick of noise) BMS CP 550i 351m rims with 275/245 set up. No tune as of yet. |
06-13-2020, 06:07 AM | #3 | |
Rep 73
06-13-2020, 04:55 PM | #5 | |
F36 GC
143
Rep 259
06-15-2020, 06:16 AM | #6 | |
Rep 41
D016F2 - Check control display, driving dynamics, receiver ICM, transmitter EDC D0193C - predefined damper passive component, receiver ICM, transmitter EDC No idea what this is... I replaced the stock suspension to KW DDC coilover 8 months ago, and everything was fine. When I was tuning I had my car on a hub dyno...dunno if that played part or not...
06-15-2020, 08:14 AM | #7 | |
Rep 73
I'm assuming you have adaptive suspension. If it's been working fine all this time, it might be a loose wire, bad sensor or need to be coded |
11-21-2021, 08:44 PM | #9 |
Rep 53
I'm glad I found this. I had the same issue (Drivetrain malfunction) after a hard pull. The scan showed the same two codes: D016F2 and D0193C. It turns out it was a 5A fuse that was gone, but I think it was because my meth injection uses that circuit as a power supply.
12-07-2021, 07:02 PM | #11 |
Rep 2
