BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > Who here is running BM3 Stage 2 93?
      02-20-2024, 06:17 PM   #23
Sammy17
Drives: 440ix, x3m
Originally Posted by Doctor X View Post
You're running E50 with the TU Pump?
AFAIK, the TU pump often cuts out at e50 its recommended to use it with a flex fuel kit that can adjust the tune accordingly and eliminate the fuel cut out issue all together since the TU pump can't flow enough.
      02-20-2024, 07:42 PM   #24
n55david
n55david's Avatar
2017 m240i xDrive  [0.00]
2015 X3 x35i  [0.00]
2015 335i xdrive  [0.00]
Correct, you can't run full e50 on the tu pump without issues. You either need a better pump or you can reach out to ptf and they will give you a new map to run on e45 to e50 that's slightly less aggressive
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
Sammy1738.50
      02-21-2024, 08:22 AM   #25
Brayton
Brayton's Avatar
Drives: 2014 435i coupe
Originally Posted by n55david View Post
Log it.. your mix is probably way wrong
i posted logs
      02-21-2024, 03:35 PM   #26
sigterm2.0
sigterm2.0's Avatar
Drives: BMW 340i
Yikes... $500 later... That is disappointing to hear. I guess I'll have a very slightly used TU pump for sale soon. 🤣😂
n55david1295.50
      02-21-2024, 03:37 PM   #27
n55david
n55david's Avatar
2015 X3 x35i  [0.00]
Yeah. Most people don't know that because all the mhd guys can run it since mhd isn't as aggressive power wise.
      02-21-2024, 03:55 PM   #28
sigterm2.0
sigterm2.0's Avatar
Drives: BMW 340i
Ugh... That was probably why I got confused. Originally I was gonna run MHD, but ultimately decided on BM3 for map editing. Sigh... Live and learn I guess. 😁
      02-21-2024, 04:08 PM   #29
n55david
n55david's Avatar
2015 X3 x35i  [0.00]
On the positive side. If you plan on staying ots maps and change the pump you'll make more power.
      02-22-2024, 09:48 AM   #30
XxThe_RemedyXx
XxThe_RemedyXx's Avatar
967
Drives: 2016 340i xDrive
I was running BM3 Stage 2 93 OTS pump on my TU pump but my fuel is shit, so I switched to Stage 2 91 OTS and timing corrections cleaned up a great deal. Car is much happier with this map.
      03-20-2024, 03:34 PM   #31
NickNack11
Drives: BMW 440
Originally Posted by bmwenjoyer View Post
I also recommend this. I was having timing issues with my Stage 2+ 93 tune and once I started mixing it with ethanol, even just a gallon or two on the 93 tune with the TU pump, my car was really happy.
I usually run the Stage 2+ E50 tune though because the power is incredible and addicting
Have you had any issues running the OTS e50 map on the tu pump?
      03-21-2024, 07:03 PM   #32
n55david
n55david's Avatar
2015 X3 x35i  [0.00]
Most people do.. you need a better pump for the bm3 e50 map.
With that being said, if you have the tu pump you can contact them through their support and they will send you an updated map that is slightly less aggressive so it works woth the tu pump.
      03-31-2024, 11:57 AM   #33
bmwenjoyer
bmwenjoyer's Avatar
33
Drives: 2018 340i xDrive
Nope no issues other than the time where I accidentally went over E50 and the car wasn't running right. I think E30 is the sweet spot with the Stage 2+ E30 tune, but E50 rips as well.
Chicago (@gp_f30 on insta)
F30 340i xDrive M-Sport (Alpine/Coral) Stage 2+
F30 335i (Alpine/Coral) - SOLD
      03-31-2024, 05:32 PM   #34
n55david
n55david's Avatar
2015 X3 x35i  [0.00]
Some people can't get to a true e50 on the tu pump.. it's best to assume that you can't.
