BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > Official B58 HPFP Options
      11-20-2023, 02:04 AM   #617
M2C
Drives: BMW M140i xDrive
Hey guys, at which pressure (PSI) is the limit of the TU pump? Actually, I'm running 25 PSI without ethanol, but would like to kow how much buffer I have. I guess it should be somewhere around 26-27 PSI, right?
      11-21-2023, 10:49 AM   #618
kern417
Cheapskate
4450
Drives: 2018 440i |2016 340i | 2010 X5
Nobody can really answer that question. The limit is based on airflow, not pressure. And airflow varies depending on the turbo amongst other things. Log your tune to know if you're hitting the limit or not.
Youtube/Instagram/TikTok: @kern417
      01-02-2024, 05:38 AM   #619
TunaFlapjack
Drives: M140i
Torque Settings
Morning, can i get people's thoughts on the torque setting discussed in ITSA+ as i have seen differing opinions on forums.
I have seen people saying they snap the bolts often when tighten to the below torque settings (Is this becuse they didnt replace the M10's)
the M10's on mine are of differing types see below photo.
Also i see that for the HPFP that the Torque settings are different for inlet/outlet & Rail connections as follows
Inlet side of the HPFP = 26Nm
Outlet side & Rail connections 26Nm
Are people following these above or just tightning to feel? (Don't like that idea on the M10's given its a strut)
Cheers
TF
      01-02-2024, 04:44 PM   #620
SC_B5X
Built Motor F30 340i
SC_B5X's Avatar
403
Drives: Built Motor 2016 BMW 340i
[IMG ]https://ibb.co/x1ydBww[/IMG]
[IMG ]https://ibb.co/TYn63ZN[/IMG]
[IMG ]https://ibb.co/TKXpsrm[/IMG]
Cheers
TF
I've never personally torqued these to spec, just tighten the hell out of them and called it a day. Never had an issue. Only thing I've torqued to spec is mounting the actual HPFP.
On another note, damn, I forgot about this post completely. Maybe when I have some time I'll go through and update this post. Been years since I've been active here.
Owner of MRM Performance
Sales@MRMPerformance.com
Built Motor BMW 340i
      01-28-2024, 05:23 PM   #621
M.S1KRR
Drives: BMW 440iX MPPSK Gran Coupe LCI
HPFP and Ethanol
Hi Guys,
Recently joined this forum. Sorry if this question might have been asked already.
Currently have done the following mods on a 440iX GC LCI with the MPPSK:
- Catless DP
- Stage 1 Dorch HPFP
- MST cold air intake
- XHP stage 3
Currently running a custom stage 2 tune by Mosselman Turbo systems (one of if not the best BMW tuner in The Netherlands).
My question is since i have an upgrade HPFP can i run an E30 mix without a flex fuel? I read on a couple threads that the ECU automatically changes the AFR etc. But this is limited to a max of E30 and not more. Can somebody confirm this please.
      01-28-2024, 05:36 PM   #622
Skyhigh
Skyhigh's Avatar
1890
Drives: BMW F36
If you have a corresponding tune, you can even run E85! The ECU adjusts according to your tune! What you have read is valid for stock tune.
If your tune is not E30, then there would be no point of doing it and potentially some harm. Flex fuel has little to do with it - flex fuel adjusts the map on the go according to your E content. Without it, you need to manually ensure fuel and map match.
      03-17-2024, 05:41 AM   #623
Marc R
Mr Anderson,we've been expecting you...
Marc R's Avatar
26
Drives: X3 M40i
Hi Guys,
Is this the correct TU pump?
https://www.ebay.de/itm/235458819572...Bk9SR4zWo7_JYw
      03-18-2024, 07:14 AM   #624
Marc R
Marc R's Avatar
26
Drives: X3 M40i
Anyone who can conform?
      03-18-2024, 10:40 AM   #625
Dantesboyz
recovering e36er
Dantesboyz's Avatar
Drives: 2017 M240i Xdrive
The bosch TU pump part number is...
I just sold mine that I had
2017 F22 M240i, Xdrive, M Performance Package
Active Autowerke Downpipe, Dinan Carbon Fiber Intake, Dinan Carbon Fiber Turbo Inlet, Dinan Mid-pipe, xHP Flashtool, MHD Stage 2
To do next list- #1- Wheel Spacers & Tires, #2- B58 TU Pump, #3- Flex Fuel Kit
