BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > 120408 and 123432 after spark plugs change/engine cleanup
proTUNING Freaks
      04-30-2020, 06:58 AM   #1
luke1990
Drives: G30 540ix
Hi guys, I have stage 3 car on BM3 custom tune (pure 800, dp, chargepipe, wmi, BMS CAI, TU HPFP) and had spark plugs changed for the supra ones and also the engine and fuel injectors cleaned for carbon deposits. The cleaning guys gave me some additive to put in 1 fuel tank to finish it. Of course me being me I went to test the car and low and behold it was slower .
Made logs which indicate more pulled timings down low (same top-up, but more pulls down low across more cylinders). At the end of the drive, I got drivetrain malufunction and reduced power. I checked the codes and among the ones i know of, I found 2 key ones:
Engine (DME) 123432 Electric Wastegate, Stop Learning: Stop position (weastegate closed) outside tolerance
Engine (DME) 120408 Change pressure control, shutdown: pressure build-locked
My question is - can these be tied to the spark plugs change or the engine cleanup? I found thread here that mentioned a suggestion which solved their problem and they also had spark plugs changed: "The vacuum lines to the pressure converter were installed backwards" -> can this be it? THANKS!
      04-30-2020, 10:05 AM   #2
conradb58
conradb58's Avatar
Drives: 2022 M240I Thundernight Metall
Subbed, need to know if we can run "Supra plugs" in B58 Gen 1 engines.
YT: Conrad B
IG: conradb_93
      04-30-2020, 10:50 AM   #3
eksigned
eksigned's Avatar
139
Drives: 4er
what was the part number on the supra plugs? NGK 94201 is the plug correct for the B58 gen 1.
      04-30-2020, 11:12 AM   #4
luke1990
Drives: G30 540ix
Hey guys -> its these plugs part#: 12122455258. It is no questions if you can run them - I know people can - many do. Question is what went wrong in my case
      04-30-2020, 11:56 AM   #5
eksigned
eksigned's Avatar
139
Drives: 4er
Pretty sure there's been discussion on different plugs vs the correct ones. Looks like those fit the G20? Don't recall what the end conversation was, but people had issues, others did not. Meanwhile, the correct plugs have had no issues. Maybe pull them and start checking for damage?
      04-30-2020, 01:46 PM   #6
G.Newt
Drives: CT4-V Blackwing 6MT
https://www.bimmerforums.com/forum/s...-2013-BMW-328i
luke1990132.50
      05-02-2020, 07:59 AM   #7
kern417
Cheapskate
4450
Drives: 2018 440i |2016 340i | 2010 X5
Did you already have the turbo installed, or was it installed at the same time? It sounds like you need to do a wastegate adaptation.
Youtube/Instagram/TikTok: @kern417
luke1990132.50
      05-02-2020, 08:03 AM   #8
luke1990
Drives: G30 540ix
Turbo was installed a month back :/. Car was fine. But as I said I had the engine cleaned for carbon - maybe they messed something up?
Either way. How would I go about doing that? Can a shop do it?
      07-14-2021, 11:00 PM   #9
say2paul
Drives: BMW 328i xDrive
How did you solve it? i am having the same issue with my 328i xDrive
      07-15-2021, 07:55 AM   #10
T_H_O_M_A_S
Drives: M140i
why the change to tu plugs ?? oem's are just fine , like many threads in this section , they change plugs and after a while they ran into codes or other problems
M140i DP , OPF delete , MHD stg2 93oct , xhp stg3
      03-12-2024, 09:56 PM   #11
alrifaieh
Drives: 2016 bmw 340i
Did u ever figure it out
      04-06-2024, 06:31 PM   #12
viktorbaffil
Drives: BMW X6
Hey guys
My 2015 bmw x6 is having exactly the same error codes as some of you here.
The screen shows the drivetrain malfunction
Note that the spark plugs were replaced 4 months ago.
Can anyone explain how it was to fix it?
Did you take it to a dealer? And how much it was?
Any info will be appreciated
123401 electric wastegate, learning stop: malfunction during catalyc converter heating
123432 electric wastegate, learning stop: stop position (wastegate closed) outside valid range
120408 chargin pressure control, deactivation: pressure build-up blocked
      04-07-2024, 03:43 PM   #13
G.Newt
Originally Posted by viktorbaffil View Post
Hey guys
Need to replace your wastegate, spark plugs have nothing to do with it.
2022 CT4-V Blackwing 6-speed
SOLD: 2016 340i xDrive 6-speed
DAW v2.5 turbo E40 | Dorch S2 | VRSF DP | MST intake | AWE catback | 335is clutch | CSF heat exchanger | RK Autowerks intake manifold | Orange M Perf Brake Kit | KW Street Comfort coilovers | GTS taillights V2
      04-09-2024, 05:10 AM   #14
Beast.58
Drives: 2019 BMW 540i
Did you guys w this issue unplug your battery when changing the plugs?
      04-11-2024, 03:13 AM   #15
Fast_Rabbi
Drives: M140ix
That doesn't change anything to unplug the battery for a sparkplugs change.
