BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > TU HPFP with Stage 2+
      03-12-2024, 11:07 AM   #23
Skyhigh
Skyhigh's Avatar
1890
Drives: BMW F36
If you can’t do 4th gear due to speed/safety, do 3rd gear. That would be good alenough too. FULL throttle through the ENTIRE range!
      03-12-2024, 02:12 PM   #24
delarock
Drives: BMW 540XI
ok guys this should be fine
https://datazap.me/u/delarock/log-17...og=0&data=3-20
https://datazap.me/u/delarock/log-17...og=1&data=3-20
      03-12-2024, 02:29 PM   #25
DieselDuck
DieselDuck's Avatar
86
Drives: BMWB58
Haha, this is only from 3000 to 4500 rpm, so still far from a complete log. But at least the data that is there looks good.
You really can't make a log from 2500 to 6500rpm ? In one gear. Anyways you're probably fine from what I can tell with the little info you give us.
M140i - MHD Stage 2+ E40 - XHP Stage 3 - Catless DP - TU HPFP - MP LSD - MP Exhaust - Endless ME20 brakepads w/ Castrol SRF fluid - Bilstein B12 - Millway solid rear subframe bushings - Goodyear Eagle F1 SuperSport
      03-12-2024, 02:31 PM   #26
delarock
Drives: BMW 540XI
hmm i dont understand it i séwear a start log at 2500 rpm on gear 4 and ended on 7000 ... i will check once more ig i uploaded correct log
      03-12-2024, 02:43 PM   #27
delarock
Drives: BMW 540XI
here is stage 2+ with up to 6700 rpm
      03-12-2024, 03:01 PM   #28
DieselDuck
DieselDuck's Avatar
86
Drives: BMWB58
It's looking good anyways
      03-12-2024, 03:40 PM   #29
delarock
Drives: BMW 540XI
Thanks, checking Stg2 graphs and one is up to 5900 rpm but understand 6500 will be more suitable.
I have few stupid questions:
1. Is it normal that stage 2 comparing to 2+ feel more torqui at lower rpms? Iam not sure maybe just a feeling but i dont feel much difference betwen Stage 2 and stage 2+
2 What about cylinder corrections? F.e. on stg2+ log cylinder 1 and 2 looks weird, nr. 3 4 5 6 are fine. Are these values normal ? I would like to keep vechichle for longer time (next car gonna be full electric bimmer) Should be there zero values? Does my car have misfires ? MHD doenst have misfire counter like bimmer link f.e. which is showing misfire occasionaly.
thanks for answers !
      03-12-2024, 04:09 PM   #30
DieselDuck
DieselDuck's Avatar
86
Drives: BMWB58
This is something I been reading by other people too, that they don't feel a difference. I wonder if it has to do with what MHD version you are on, or if it matters you are on multi-map or not. All I can say, is that when I did log the Stage 2+ pump map (93oct/98ron) I had around 19 psi mid range so it is DEFINITELY stronger than "normal" Stage 2 which doesn't even come close to 19 psi. I do have to say I have good quality fuel and barely ever have any timing corrections.
This is an old Stage 2+ 98 log of mine but it wasn't the best log either and I think I had wheelspin, but it seems my boost target was higher than yours.
https://datazap.me/u/zd/mhd-stg2-98r...40-41-42-43-44
Most importantly your car runs safe and log looks good
      03-12-2024, 06:12 PM   #31
Skyhigh
Skyhigh's Avatar
1890
Drives: BMW F36
1. There isn't much difference between Stage 2 and Stage 2+ on RON 98! This has been declared by MHD too. The max power is the same, only slight improvement is in mid-range, according to MHD. With RON 98, you are octane limited and not fuel quantity limited, which is why a HPFP upgrade brings very little. Which is why it took long for MHD to even introduce Stage 2+ RON 98 as initially they were claiming there isn't anything to gain at all. This said, you should not feel Stage 2 "torquier" than Stage 2+. That is rather weird. Maybe a subjective thing.
2. Again - it is not the individual numbers that can be given thumbs up or thumbs down.... one needs to look at the big picture! small corrections on individual cylinders occasionally are totally normal. Continuous corrections, which don't really clear up and on the same cylinders can indicate something else! So do not get locked by digits in isolation! That's why people analyse logs, not values.
      03-13-2024, 05:28 AM   #32
delarock
Drives: BMW 540XI
Thank you guys for relevant answers
So my last considertion is if i should change my sparks and coils because of corrections. i red all the forum some people said its normal, some that there should be there etc.
      03-13-2024, 06:22 AM   #33
Skyhigh
Skyhigh's Avatar
1890
Drives: BMW F36
Changing sparks and coils will not do anything for you! Some corrections are normal. If you want to have less to none - you need higher octane fuel / Ethanol.
      03-13-2024, 06:57 AM   #34
Skyhigh
Skyhigh's Avatar
1890
Drives: BMW F36
P.s. You need to take into account that even on a completely stock vehicle and tune or the BMW MPPSK, you would still have some random timing corrections, especially if you drive on RON 95 or lower. It is just the electronics doing what they are supposed to do in order to maintain a safety net.
This said, do not think that if logs are good, then your vehicle is perfectly fine with any tune! Don't forget that the combustion process (which is essentially all we are monitoring using the logs) is only one side of the story. Another is all the mechanical stress, extra load on engine, gearbox, drivetrain, etc... All of us seem to easily forget that.
      03-13-2024, 11:12 AM   #35
delarock
Drives: BMW 540XI
Yes i realize that any tune is lowering lifetime of vehichle parts…
But to be honest i use the power just for overtaking 99 percent i drive according to regulations.
I would like to ask 2 questions : In england is possibility to improve HP50 with HP75 parts , sadly in continental europe i did find any simillar solution.
What is value knock interpolation?
      03-16-2024, 08:46 AM   #36
delarock
Drives: BMW 540XI
Today i realized that i have much higher corrections on RON 100 fuel from another gas station(omv) comparing to Slovnaft (mol group) its surprising little bit
      03-16-2024, 08:49 AM   #37
Skyhigh
Skyhigh's Avatar
1890
Drives: BMW F36
Not surprising at all. You may even realise you get different quality fuel from different stations within the same chain. It also has to do with how old the fuel is. But also take the environmental conditions into account. It is to be expected to get more corrections as temperatures increase.
      03-16-2024, 09:06 AM   #38
delarock
Drives: BMW 540XI
Sky do you have during regular ride such a high corrections sometimes on every cyllinder? check pls around 180 secs there are areas of high corrections during calm ride. i know its not proper log but i ride with this style 99 percent of time ..
As i mentioned its much worse now on omv ron 100 fuel
      03-16-2024, 02:40 PM   #39
Skyhigh
Skyhigh's Avatar
1890
Drives: BMW F36
You should not judge by logs which are not WOT. The data is simply irrelevant. To have a datum, you need to always log at WOT. Anything else has too many variables to compare.
      03-16-2024, 02:47 PM   #40
delarock
Drives: BMW 540XI
yes you are right... i posted wot log in the log section its not ideal but i think i should stop loging😀😀and will keep ron 98 stage 2
