      11-23-2021, 09:51 AM   #16039
shawnsheridan
shawnsheridan's Avatar
Originally Posted by cjn View Post
Sean, would you be kind enough to send the latest ESys package. I'm now a couple of years out of date.
Also, which F-series data set is used for a 2021 F40 M135i car?
Thank you.
PM sent.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      11-25-2021, 11:21 AM   #16040
diem
Drives: BMW F31 2015
Hi Shawn
Could you also send me the latest e-sys PM?
I've got a cable but would be my first time setting it up.
Thanks
      11-25-2021, 11:22 AM   #16041
shawnsheridan
Originally Posted by diem View Post
Hi Shawn
Thanks
Your Receive PM function is disabled. PM me when working.
      11-29-2021, 03:29 AM   #16042
Mch81
Drives: bmw g31
Hi guys,
I am new to Esys coding. I used NCS expert for E series, but planning to buy G31 and I want to have same ability to do small changes.
1) I have problem with Launcher. I have MAC and I virtualise WIN1903 via parallels.
E-Sys_Setup-3.27.1_RC_b44813
E-Sys Launcher PRO 2.8.2_Build_162b BFU Edition
ESysLauncherPremiumSetup_2.8.2_Build_155
PSDZDATA 4.27.22
I did all installation but when I run Launcher Preminum, it did not start at all.
I figured ou that for virtualisation I need Launcher PRO.
All is good until providing password and activating. App falls down and when I want to open activation window again it falls down.
Do you have any clue what could be the issue?
I have installed JAVA 8, C++ version 2010 x86/64, WIN 20H2 and nothing helped.
I have read that there is version 3.x to use, but TM has disappeared and don't know how to activate it.
2) does any of you any have cheat sheet for G31?
3) if I mess anything with car. Will I be able to return back with backed up ECUs?
4) If I talk only about coding ECUs, is Bimmercode good alternative with same options (especially expert mode)?
Thank you for any help.
Michal
      11-29-2021, 01:22 PM   #16043
shawnsheridan
Originally Posted by Mch81 View Post
Hi guys,
PSDZDATA 4.27.22
Michal
Launcher PRO does NOT support VM use anymore than Launcher PREMIUM does. With MAC, you need to use Bootcamp or VMWare VM with modified .vmx file.
Cheat Codes are built into E-Sys Launcher.
I can't comment on "mess anything with car". That would depend on what if anything got messed up. Generally speaking, if just coding, it can always be set back to factory just by VO Coding.
I also can't comment on Bimmercode. I don't use it myself.
      11-30-2021, 04:23 AM   #16044
Mch81
Drives: bmw g31
Thank you Shawn! really appreciate what you do here.
OK, I will have to use my wife's laptop
Just to confirm - to fix via VO coding you mean remove VO and add it back. right?
for that I need full version od PSDZData, don't I?
What version of Esys and Launcher would you recommend?
Thank you.
Michal
      11-30-2021, 07:05 AM   #16045
shawnsheridan
Thank you.
Michal
I mean VO Code the ECU using original unmodified FA. Full needed ONLY for flashing. I use LE-Sys 3.27.1 and Launcher PRO 2.8.2 for FDL Coding.
      11-30-2021, 09:45 AM   #16046
Mch81
Drives: bmw g31
thank you
      11-30-2021, 10:56 PM   #16047
AriZoNaiCe
Drives: 2014 335xi M-Sport
Hi Shawn -- would you mind sending me the most current Esys and psdzdata info? I have an F30 that I'd like to code.
Using what I've found around the web seems to tell me that 3.27.1 is the "best" version to use, but that with a newer psdzdata results in an error in KisAlAdapater "Unsupported major.minor version 52.0", which I guess means that was compiled against Java 8 and we depend on Java 7 for Esys 3.27.1.
**Update**
The above error is the result of running Esys Launcher in a VM. There are published workarounds that require using VMware (not VirtualBox) and editing the .vmx file for your VM. In a VM, Esys is a bit slow and requires slightly more effort to get functioning, so it's recommended not to use a VM unless you are pretty comfortable with what that may entail.
      11-30-2021, 10:59 PM   #16048
shawnsheridan
I'm posting this here in hopes I can post a reply once I get figured out to help others, in case they run into the same. :-)
Thanks!
I FDL Code with E-Sy s3.27.1 and latest PSdZData. PM sent.
      12-02-2021, 07:03 PM   #16049
brokaens
Drives: BMW 320d
Is there a way to code out the auto start stop so it's default is off?
      12-02-2021, 09:07 PM   #16050
shawnsheridan
Depends on car.
      12-05-2021, 02:40 PM   #16051
AriZoNaiCe
Thanks, Shawn -- correct, as usual! If anyone else is struggling with this, another thing you can/should check is local firewall (Windows Defender Firewall in Windows 10). Once I disabled that, I was able to connect with no problem.
This is also true if using a VM, in which case you need to disable the default Firewall on *BOTH* the Host machine and the VM.
Thanks to Shawn and the entire community -- hugely helpful!
      12-05-2021, 02:48 PM   #16052
shawnsheridan
      12-08-2021, 04:10 PM   #16053
mmmm_beer
Drives: 2019 430i Convertible
Hi Shawn,
Could I also get the latest E-Sys package? My car is a 2019 F33 if that makes a difference.
Thanks!
      12-08-2021, 04:12 PM   #16054
shawnsheridan
Originally Posted by mmmm_beer View Post
Hi Shawn,
Thanks!
PM sent.
      12-12-2021, 06:46 PM   #16055
PearlWhite
Drives: BMW 340i
Hi everyone,
I have a F30 340i on which I have used e-sys to do coding.
I would like to code to deactivate "IHKA - Recirculation Function Changes from Manual to Automatic", as I prefer to keep air recirculation permenantly ON when I toggle Manual.
I was reading official dealer service bulletins such as the below:
https://testing-public.carmd.com/Tsb...0B64%2005%2015
https://static.nhtsa.gov/odi/tsbs/20...48058-9999.pdf
In which they used ISTA-P to alter the IHKA function
Is there a way to do the same using e-sys?
Many thanks!
      12-12-2021, 06:58 PM   #16056
shawnsheridan
Originally Posted by PearlWhite View Post
Hi everyone,
Many thanks!
Yes. Add HO-Wort "DAUE" to FA and VO Code IHKA.
      12-12-2021, 07:31 PM   #16057
PearlWhite
Drives: BMW 340i
Thanks Shawn!
Regarding your advice, "Add HO-Wort "DAUE" to FA and VO Code IHKA" I will look up what it means!
I saw another forum post which suggested the following changes under IHKA module:
mist avoidance BESCHLAGSVERMEIDUNG = NICHT AKTIV
auto recirculation off UMLUFT AUTO AUS = NICHT AKTIV
HEIEN IN UMLUFT = AKTIV
Not sure if anyone has had experience with the above, and whether they work to keep Manual mode cabin air recirculation to stay on
      12-12-2021, 07:39 PM   #16058
shawnsheridan
Thanks Shawn!
Those are FDL Codes, and if they are the correct FDL Codes, they would be set automatically by VO Coding IHKA with HO-Wort "DAUE".
Per SI B64 05 15 Heating and Air Conditioning you attached:
Perform a conversion with ISTA/P "Deactivation of the automatic air recirculation control".
The final report shows the VO modified with K-Word "DAUE". The air recirculation button will function in
manual mode only.
      12-13-2021, 03:47 AM   #16059
favourhisashi
Drives: F30 328i sport
Hi Shawn,
Can you please send me the links for the latest psdzdata, thank you.
      12-13-2021, 09:12 AM   #16060
shawnsheridan
Originally Posted by favourhisashi View Post
Hi Shawn,
PM sent.
