12-02-2022, 04:12 AM | #1 |
Rep 204
N55 Idle question.
How smooth is your N55 when idle? Mine seems to be fine, but you can feel very slight hiccup when on traffic lights (even less when on P. When It is D can feel It a bit more). Nothing really bad, just wondering if all N55s have this behavior. It is different, much different when AC is on. I can feel the same thing, but few times harder. Rpms are like glued, doesnt move at all, steady. Spark plugs brand new. no other symptoms. Does it even worth to pay attention?
Drive this car 5years, but maybe before I was not focused on It. Because thousand miles ago I had a problem with missifre, so I changed the spark plugs. Thats why I try to catch if there is some misfire maybe, so I am more focused on It. Car runs fine, has power, No misfire, No codes. |
12-02-2022, 10:52 AM | #2 |
Rep 7,591
Idle should be smooth, shouldn't feel anything especially when in D. Could be any number of things...coils, MAF, etc. If no other symptoms probably not losing sleep over, just monitor and make sure it doesn't get worse.
Jvac432.00 |
12-02-2022, 11:23 AM | #3 |
Rep 785
+1 n55 is the smoothest engine I've ever owned. Purrs like a kitten at 45000mi on original plugs and coils. But, as enthusiasts I think we pay a little too much attention to the most minor things. Running well and not throwing any fault codes? Leave it alone and stick to the scheduled maintenance plan. No sense throwing parts and money at a car trying to achieve perfection. These are mass - produced consumer cars, even though I like to think I'm special for owning one. There's bound to be some flaws that are not indicative of anything serious.
335i rwd auto, 2015 with m performance LSD and Dinan stage 2. Cts charge pipe, mad 5" stepped intercooler.
12-02-2022, 01:50 PM | #4 |
Rep 408
Mine was smooth at idle until I replaced all 6 coils due to a misfire (bad #6 coil). Now it's incredibly smooth idling. Even with the AC on.
My 2c 2015 335i Msport 137,000 miles |
12-02-2022, 06:31 PM | #7 |
Rep 7,591
12-03-2022, 07:01 AM | #8 |
Rep 204
I have refilled the tank with the fuel I am sure is high quality. I am not sure, but seems to be better.
I think, you guys get my description like my car shakes a lot. :-) And It can be my bad. It is VERY slight vibrations, like somebody would kick ‚gently’ my front tire. 😀 My gf is not even able to feel it. That’s what she says. The biggest ‚issue’ is when you turn on AC during the stop and this ‚seat massage’ takes like 15sec and then is okay. |
12-03-2022, 09:27 AM | #9 |
Rep 1,560
What did you use to pull the codes? If your code reader isn't designed to pull BMW codes you may be missing some codes from some modules.
Some codes don't show up on some readers unless they reach a certain threshold. With some issues the car will keep track of the number of times it happens, but won't trigger any lights until a certain level is reached.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. Looking for new home.
2022 Z4 M40i, Misano Blue Metallic, Driver Asst Pkg, Prem Pkg 2023 X5 M50i, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg. |
