03-13-2017, 03:58 AM | #1 |
Rep 1,772
Australia NZ 2017-1 Map for d/l
This is for NBT
Aus NZ Next 2017-1 Please do not ask me if it will work for this or that car. I am creating this torrent for you to download, please continue to seed so others can download as I will not keep it open indefinitely. I cant attach torrent files as is so i have renamed the file *.pdf. Download the file and then change the extension from .pdf to .torrent Once done just double click on it and should start the download (assuming you already have utorrent program) This is first time I am creating a torrent file so hopefully ive done it correctly! |
03-13-2017, 04:06 AM | #2 |
Rep 1,772
This is just the map, you will still need to buy or create your own fsc.
There are instructions in this forum on how to create your own fsc, just search. Please let others download off you once your download is complete, do not be a leech! |
rednose65.00 |
03-14-2017, 07:04 AM | #5 |
Rep 365
Yep,
Big thanks go out to x5mad for supplying the maps. For anyone that gets stuck creating the fsc code, new short code in xml lookup is 00AA002A George |
03-15-2017, 08:36 AM | #6 |
Rep 10
Followed pdf instructions and used an 8gb USB stick formatted in FAT32 - no other partitions, copied files to root - but unable to get the update prompt after inserting into center console port. Any suggestions would be appreciated.
2014 F30 328i EB, Opticoat Pro, BMS Stage 1, MPE, MP rear diffuser, skirts, front lip & spoiler
03-15-2017, 02:00 PM | #7 |
Rep 365
If you plug it into a pc do you see this folder?
NAVD_000014BA_255_004_168 if so then thats your problem. You should only have the following files: 1 config.nfm NBT_AUSNZ_142161.3.112.pkg NBT_AUSNZ_142161.3.112.pkg.sig |
03-15-2017, 05:46 PM | #8 |
Rep 10
Thanks rednose,
Yes, the 4 files sit on the root of the usb key. The same usb key was used successfully to install ConnectedDrive update, so I know the usb key (Sandisk Cruzer 8GB - FAT32) can be detected and read from.
03-16-2017, 01:48 AM | #9 |
Rep 365
Is the car on when you plug in the usb?
I plugged mine in first, then pushed the start button (without the pressing the brake) and it detected the update. Also, do you have 1 usb port or 2? Some have a usb port in the glove compartment aswell, if so, try the one in the centre console |
03-16-2017, 04:59 AM | #10 |
Rep 10
Thanks rednose - update successfully completed.
Compared your file list to mine and noticed the config file had an extra file extension which requires renaming back to original - config.nfm. The rest was as you described using the center console USB port. Thanks also to x5mad for the maps.
rednose65.00 |
03-16-2017, 08:13 AM | #11 |
Rep 18
Drives: AUDI RS5 Sportback 2022
Thanks x5mad for the NEXT maps. Don't suppose you or anyone has a link for the Premium (CIC) 2017 version.
06-08-2017, 12:27 AM | #14 |
320i F30 Sportline
41
Rep 62
Hey mate, couldn't see any attachment that shows the steps to update. Can you share it once more please? Also, did you get the FSC code generator from the guy who's posted it in one of the bimmerpost forums?
06-08-2017, 06:47 PM | #15 | |
Rep 3,225
You can generate your own code for free (there is a thread in the coding section telling you how to do it) or you can Dragon to create a code for you for $50US. |
06-28-2017, 11:19 PM | #16 |
Rep 1
Help?
I really would love to get these maps and attempt to perform an update but I have tried to download them for a week and it doesn't start. Can someone help me, please, beg?
I'm in Melbourne. Sorry if I am being stupid but really would like to update my maps. |
07-28-2017, 03:14 AM | #17 |
Rep 33
Hi guys,
Would appreciate if people could put the torrent back up as there are currently no seeders. Alternate suggestions would be appreciated. |
07-28-2017, 07:36 AM | #18 | |
Rep 230
Price is close enough to buying the FSC/Download - most were at least USD 50 per update. Obviously cheaper if you roll your own FSC and can get the download but a lot more reasonable than the past! |
07-30-2017, 08:37 PM | #19 |
Rep 21
08-13-2017, 11:21 PM | #21 |
Rep 4,021
Drives: F32 Coupé
Hey guys is this still up? I'm only getting failed connections. (Could just be that all the seeders are currently offline but thought I'd ask...)
