04-08-2019, 11:22 PM | #221 |
Rep 38
Heated wheel
Hey guys..would you guys be able to tell if this steering is heated? I have a f10 LCI with heated options minus the paddles..i want to swap out for this to add paddles. seller states its from a 2018 340m. if it is heated, when i swap out, do i only have to code the paddles? also would this fit a f10?..
thank you guys in advance. |
09-22-2019, 04:09 PM | #222 |
Rep 10
Hello, can someone post pinout of the switch, I got this button without connectors and can not find any wiring diagram with pins of this button. thank you
09-23-2019, 02:10 AM | #223 | |
Rep 8,970
But as far as I'm aware the switch isn't available without the wires??? Functional description https://www.newtis.info/tisv2/a/en/f...d-lim/GSG5G1L0 item S10 on here https://www.newtis.info/tisv2/a/en/f...ating/FpfYyaDs |
09-23-2019, 03:20 AM | #224 | |
Rep 10
I bought used Trim panel with button included and it was without wires |
09-23-2019, 03:40 AM | #225 |
Rep 8,970
If it was a plug at the switch the diagram should show it.. Definitely on mine the wires from the switch were fixed to the switch.
But you should be able to work it out with a multimeter. There is only 3 pins. Ground, switch and LED. |
09-23-2019, 04:00 AM | #226 |
Rep 10
Mine has a plug at the switch
09-23-2019, 05:47 AM | #227 |
Rep 8,970
09-23-2019, 06:17 AM | #228 |
Rep 10
09-23-2019, 06:49 AM | #229 |
Rep 8,970
Is your switch this part? https://www.realoem.com/bmw/enUS/par...&q=61319384363
It's the same for al 1, 2, 3, 4 series. It is shown with lead attached and no part code for the separate lead. Maybe just buy a new switch? it won't cost a lot. |
09-23-2019, 10:15 AM | #230 | |
Rep 173
Drives: BMW 340i Touring, Aston Martin
Anyone want to buy a switch without a cable? No, didn't think so |
03-02-2020, 02:19 AM | #232 |
Rep 11
Hello
I did retrofit my steering wheel with the vibrator, new cable, and LRE in order to use LDW. I installed the buttons console as well I have not heater, but in spain.. this is not necessary.. 32336787451 vibrator 61319218381 module 32306854771 extended cable 61319268479 buttons console 51459239299 new console molding In my current SZL 61319351145 (small slot 4 pins, is not wired) but this slot is only for switch heated I followed the codes in bimerfest this link and I coded with e-sys all parameters When I start the car, I and touch the boton and the two yellow lanes appears, but few seconds after, de LDW is desactivated and does not work. a msg n HUD and KOMBI appears saying not working SLW I checked with ISTA and have this msg 030351 K-LIN 16 sterring column switch cluster (SZL): wrong version 030490 Steering wheel electronics module (LRE): Missing LIN slave I read similar topics about Heated Steering retrofit, but in my case I not going to use this, so this msg are related this SZL. I read as well that SZL need to be recoded, but i'm not sure if not changing the szl like me, but adding new functionalities, I will need to recode.... and how to do (E-sys.. ISTA P) The guy that I followed he had like most of you, the LRE already in the sterring whel, so I think that this problem can come from a missing code related with LRE I read this in other forum, here but I applied and noyhing new.. "If you are installed steering wheel Control Unit with Vibration Actuator Motor then code: LIN_VARIANTE_LRE > lre_tlc LRE_VERBAUT > aktiv " Can someone help me ?¿ Last edited by kaciker; 03-02-2020 at 02:33 PM.. |
03-05-2020, 01:54 PM | #233 |
Rep 11
05-05-2020, 02:32 PM | #235 |
Rep 8,970
05-18-2020, 04:49 AM | #236 |
Rep 102
Hey hoping someone can help i have purchased all the parts that i need but my heated steering wheel switch came without the wiring at the back. Should i buy a new switch from BMW that comes with the wires or can i buy the just the wire with the adapter/plug on its own ?
05-18-2020, 07:37 AM | #237 | |
Rep 4,456
https://www.realoem.com/bmw/enUS/par...&q=51497453333 If you can buy just the wires should be cheaper. Post 56 page 3 of my build thread shows the BMW part number for switch in package https://f30.bimmerpost.com/forums/sh...1352545&page=3 |
05-26-2020, 10:09 AM | #238 |
Rep 152
Im probably over thinking this.
I did this retrofit and the button does nothing. No light, no heat, nothing on the KOMBI. The car did not come with LDW or heating. However it does have the wires on pin 11 and 9 of the SZL plug. Am I reading correctly that even though these are there, the SZL still doesn't have the power for the heater control? I haven't had to splice into anything yet since my wheel came with the controls and harness. There is a 10a fuse in F48. Is this really as simple as snipping the heater control power wires and stuffing them into pin 1 and 3 on the airbag connector? NM, definitely over thinking it. Wheel works great this morning after the car had a chance to sit over night. I thought the coding would have taken effect a little more quickly. Last edited by pdxpeter; 05-26-2020 at 11:43 AM.. |
10-11-2020, 04:50 AM | #239 |
Rep 525
10-29-2020, 11:40 AM | #241 | |
Rep 128
Any ideas? I’ve reused my wheel loom so I’m wondering if it’s not present on that (item 5 above needs swapping maybe). I’ve added the button, added the wheel, added the module, coded and get “steering wheel heating activated/deactivated” on dash as expected - just no heat! Edit to add. 100% it is that I don’t have the correct loom. For anyone else stumbling on this thread in years to come, f you’re interested Part 32307848337 is what I’ve ordered - steering wheel loom for cars with lane departure/heated wheel. 👍 Last edited by Daggers; 10-29-2020 at 12:00 PM.. |
dholdi259.00 |
11-18-2020, 09:23 AM | #242 | |
E36M3 2/5 garage queen X3 3.0si
Rep 40
What if you do not have lane departure warning on car. I added heated msport wheel (car was standard with msport), button and module. coded via bimmercode and light comes on button but no heat. The module does have another single wire coming off it with no place to go. I assume this would be for vibrator? please help. |
f30, heated, heating, steering, wheel |
