12-14-2022, 02:53 AM | #23 |
Rep 502
Having solar and a EV on its way, it's the best decision that I think I've made in a long while. Energy prices will never go back to where they were. After any forced price hike on any commodity, when things settle prices never return. Have a look at petrol for start.
If you have a battery alongside your solar and use a tariff which is similar to the old economy 7, then you can certainly run your home on average for about £1 a day throughout the year. My supplier charges 15p per KW overnight and that can go straight in the battery or the EV. On average in the winter our 3 bed house uses 5-6KW per day, during the summer about 1-2KW as the excess from solar will power the house. In the winter we buy in about £1 of electric and in the summer about 30p. Add on the standing charges and it works out about £1 a day The only adjustments we make in the household, is both the dishwasher and washing machine go on either when the sun is out, or overnight at 15p KW rate. Yes I might break even is 5 years, yes the above maybe a little man maths until we have had the system for a full year, but I'm also doing my bit help the planet. If we all worried about when we would make our money back on everything we purchased, for a start none of us would own a car, buy a shed, buy tools, the list goes on. Some things aren't always about the money.
EX F34 320d Sport | Sept 2013 | Imperial Blue | Media | Manual |
Currently learnt a lesson |
12-14-2022, 03:28 AM | #24 | ||
Rep 8,783
Drives - 2020 LR Discovery HSE-L Previous - 2019 LR Discovery HSE-L // 2016 F36 440i // 2009 E90 320D SE |
KRS_SN13537.00 |
12-14-2022, 04:14 PM | #25 |
Rep 944
Apologies for the thread swerve.
You can look at it another way and insulate. We have a 1967 house with the upper floor built in the roof space, it had in essence no insulation. Doing what I thought was the right thing, 100mm of high density slab Rockwool behind the plasterboard walls, 175mm of loose lay Rockwool over the exposed areas of the ground floor ceiling and circa 100mm of expanded foam in the upstairs ceilings has certainly transformed the place over the last twenty years. However, with hindsight, I would go further and will look to do so even if the easiest way would be to re-roof to gain access to add further layers. Multifoil insulation certainly has a good specification for a relatively thin (circa 40mm) material. I'm considering cladding the upstairs in this. The benefits of insulation are felt both in the height of Summer as well as Winter in keeping a comfortable temperature. Literally Last edited by Techno 9000; 12-14-2022 at 04:24 PM.. |
12-17-2022, 10:52 AM | #26 |
Rep 1,671
I’ve got 4 large panels on my south facing new-build roof.
I’ve no idea of capacity or kW generated in the last year though. Probably need to do some research. |
12-17-2022, 12:56 PM | #27 |
Rep 3,216
If it's been put in as part of the planning / regs requirements, then they're probably the lowest cheapest output panels that the builder could put in - so I'd guess at them being 250-300W per panel
12-17-2022, 03:50 PM | #28 |
Rep 1,671
03-14-2023, 07:53 PM | #29 | |
Rep 3,560
I've approx 7kw system with approx 10kwh batteries. Charge the batteries over night on the cheap tarrif, house runs off the battery through day until solar kicks in. Then solar takes care of the load, charges the batteries again if required and anything else feeds back in. You have to adjust the way/times you run things but that doesn't take long to get used to. Since installed i've saved approx £380. |
02-08-2024, 06:24 AM | #30 |
Rep 1
Well, I totally get where you're coming from, mate. Electricity rates can be a real pain in the wallet. Solar panels could be a game-changer, especially in a place like Glasgow. I've also heard some good stuff about solar panels Ireland lately. They seem to be helping folks cut down on their bills, so it might be worth looking into. As for break-even time, it varies, but generally, you'll start seeing savings within a few years. Definitely worth doing some research and maybe chatting with folks who've already made the switch.
