BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Transfer case issue or not?
      03-21-2024, 07:45 PM   #1
f30james
Drives: 2015 F30 328i xdrive
I have a 2015 F30 328i XDRIVE and I've been having a stuttering issue for a while now, everything i hit the accelerate pedal more than like 40% the car starts to jolt and stutter, if i try to accelerate hard the car will go into limp mode and the "Drive Train Malfunction" pops up, but if i let off car just continues to drive fine. I've watched a bunch of videos on symptoms and a lot of people say its either your Spark plugs, coil packs and its a misfire but I've replaced those and the engine sounds healthy.
      03-22-2024, 07:15 AM   #2
Wires
Drives: 2016 340i xDrive
You need to pull codes. Without that, you are randomly guessing many things that can cause that.
      03-22-2024, 04:33 PM   #3
f30james
there are no codes and no lights on the dash that pop up when the issue occurs.
      03-22-2024, 04:43 PM   #4
dusan1080
Drives: BMW 320
Did you ever change oil in transfer case?
How much km does care have?
      03-22-2024, 07:04 PM   #5
f30james
I have about 130k miles on the car and i got it at 119k but transfer case oil hasnt been changed to my knowledge.
      03-23-2024, 11:33 AM   #6
_ObiJon
_ObiJon's Avatar
Drives: 2015 428i xDrive
Never tried this on my F32 but on my F15 (X5), you can unplug the TC to troubleshoot it.
Also, you said no codes/lights pop up but have you hooked up a scan tool?
      03-23-2024, 11:50 AM   #7
cfm56d7b
By any chance, did you inspect the vehicle prior to purchase? Buying a vehicle with 130K without an inspection comes with risks. Hopefully, the deal was attractive enough.
If you don't have a code scanner, please get one. That's the the first (and only) practical next step.
I still suggest to have a reputable indy shop to perform a detailed inspection.
      03-23-2024, 12:59 PM   #8
E36M3
Drives: 97 M3, '14 335i, '12 X3 35i
If you have a drivetrain malfunction pop up in the dash I guarantee that there are codes. What code scanner are you using?
Wires1645.50
      03-24-2024, 08:30 PM   #9
Wires
What he said^ The drivetrain malfunction will 100% be logging codes. Heck it logs codes if you trip the alarm by jacking up the car with the doors locked.
