BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Is my DME fried?
proTUNING Freaks
      03-23-2024, 10:53 AM   #1
Mwilbur06
Drives: 2013 BMW 328i x drive
Is my DME fried?
2013 bmw 328i xdrive N20 Changed my oil filter housing and oil cooler gaskets yesterday and mixed up 2 of the cam lock plugs on the DME wouldn't fire up, figured it out it starts now but I get chassis stabilisation error and 12 codes that will not clear with ista I will attach a photo of the codes. I checked all the fuses in the trunk and under the hood on the passenger side and help is greatly appreciated thanks.
      03-25-2024, 09:49 AM   #2
pshovest
BMW CCA 69606
86
Drives: '15 435i,'10 535i,'08 X5,'98M3
Any bent pins on the connectors that were mixed up?
      03-26-2024, 12:23 AM   #3
fe7565
fe7565's Avatar
Drives: 2012 BMW 328i N26
Some serious codes require time (prolonged driving. start/stop, etc) to reset. There is a way to accelerate the process by following a multi-step driving procedure. You should check, if the error codes have that status. Check, make sure you are not in "transport mode".
