03-23-2024, 04:33 PM | #1 |
Rep 7
2015 BMW 320i Xdrive won't crank
2015 BMW 320i Xdrive aka F30 with the N20 motor I believe. Couple months back my cousin replaced the brake pads on it and wear sensor. Test drove it before I left his home but before I left I plugged in this beat up portable air pump that I believe may have fried my alternator , electric coolant pump , and starter. That air pump was dragged and was ran over so it was no good. Didn’t have a problem with vehicle starting until I got the brakes changed or pumped air with that pump. Had the alternator , starter and electric coolant pump replaced and those codes cleared but I still have codes for Central Gateway Module ZGM. Front Electronic Module. Electronic Transmission Management.
Codes are: 801C20-ZGM:Central Memory Fault-No control-unit fault. 804181-Side Lights , Front ,right faulty. 420634-Position sensor: parking lock in intermediate position for too long. CF20C1-No message (group fault 3 - effect during driving: none): receiver EGS, transmitter CAS/FEM/JBE/FRM 480A11-Brake pad wear sensor: Front axle, replace brake pads 480A12-Brake pad wear sensor: Rear axle, replace brake pads2015 BMW 320i Xdrive aka F30 with the N20 motor I believe. Couple months back my cousin replaced the brake pads on it and wear sensor. Test drove it before I left his home but before I left I plugged in this beat up portable air pump that I believe may have fried my alternator , electric coolant pump , and starter. That air pump was dragged and was ran over so it was no good. Didn’t have a problem with vehicle starting until I got the brakes changed or pumped air with that pump. Had the alternator , starter and electric coolant pump replaced and those codes cleared but I still have codes for Central Gateway Module ZGM. Front Electronic Module. Electronic Transmission Management. Codes are: 801C20-ZGM:Central Memory Fault-No control-unit fault. 804181-Side Lights , Front ,right faulty. 420634-Position sensor: parking lock in intermediate position for too long. CF20C1-No message (group fault 3 - effect during driving: none): receiver EGS, transmitter CAS/FEM/JBE/FRM 480A11-Brake pad wear sensor: Front axle, replace brake pads 480A12-Brake pad wear sensor: Rear axle, replace brake pads |
