BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > F30 fault codes
      03-23-2024, 05:03 PM   #1
BMW2002FL
Drives: BMW 328i 2015, BMW 2002 1975
F30 fault codes
I have engine check light on the dash of my BMW 2015 328i F30. Advance Auto Parts read the codes using INNOVA 5510 scanner and gave me these two code
P12DD - Rear right wheel speed sensor (passenger side)
P2077 - Something to do with the temperature sensor ???
I can not find these codes listed for F30 anywhere?
Anybody has the full list!
Please help!!
Thanks
      03-24-2024, 06:56 PM   #2
BMW2002FL
I think the guy misread the codes.
I plugged in my old OBD II scanner and I got
P15DD - Wheel Speed Sensor Rear/Right Range/Performance
P0073 - Ambient Air temperature sensor circuit high input
      04-02-2024, 11:22 AM   #3
BMW2002FL
P0073 was fixed by soldering the wire eaten by a rodent.
Tried to trouble shoot P15DD by using a jumper wire from the rear right sensor to the rear left sensor. I think this was a mistake, I should have reset the codes and then see what comes up but I thought you can not reset the wheel speed sensor codes. Finally I end up with
P15C8 - Wheel speed sensor rear/left Circuit open (Permanent)
don't know how to remove this code! The check engine light is off.
Someone more knowledge may know what I did wrong to cause this code and how to reset it?
p12dd p2077 speed sensor
