03-24-2024, 10:04 PM | #1 |
Rep 3
Paddle retrofit from an f32 coupe
Hello,
I have been wanting to get paddle shifters in my f30 328i for a while but it just seemed so expensive and unattainable. I just found a f32 428i steering wheel with paddle shifters, the wheel looks to be the same as mine but it is missing an airbag. My question is can I use the paddles off of the f32 wheel in my f30 without any issues. I know that I will need to code it to my car but function wise will it work? Thanks in advance |
03-24-2024, 10:35 PM | #2 |
Crystal330ii
Rep 46
Functionally it's a direct swap I believe! Just needs a lot of supporting hardware and wiring + coding... it's a long process, there's a ton of threads out there on it I think.
03-25-2024, 03:58 PM | #3 |
Rep 106
compared to most mods, it's like a 7.5-8 out of 10. that's why I just looked for a model with paddles already.
03-31-2024, 08:39 AM | #4 |
Rep 25
Drives: BMW 218i Coupe
You will need to check if your car is pre-wired by either checking the FEM or Steering column. Much have been written about it. In terms of difficulty, I call it a 3 out of 10. Coding can be done with Bimmercode (1-2 setting only). Since you have a steering wheel, you don't need to drill either.
