BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Is my BMW F30's coolant level too low?
proTUNING Freaks
      03-25-2024, 06:10 AM   #1
reijimaho
Drives: 2015 BMW328i M Sport F30
I just refilled the coolant about a month ago. Today, I checked the coolant level and found it below the 'Min' arrow.
Is this normal or is there something wrong with the coolant system?
My car is a 2015 BMW 328i F30 with an N20 engine, with approximately 91,164 miles.
      03-25-2024, 08:07 AM   #2
eff32fl
eff32fl's Avatar
1052
Drives: 2019 440i M Sport THP MPPSK
If it's below the min level then your coolant is low. If it's under just a bit it's not a huge deal but there's a small coolant leak somewhere. I recently had to replace my coolant reservoir cap it was letting coolant evaporate. I'd check that first and if that's not the issue I'd recommend having a shop do a pressure test.
sspade2464.50
      03-25-2024, 10:02 AM   #3
sspade
sspade's Avatar
Drives: F30
2016 BMW 320i  [7.87]
2014 BMW 328i  [6.83]
Put it back to the halfway point of reservoir and keep an eye on it (as you have been).
One of my turbo seals is leaking slightly and has me dealing with the same issue as you. I’ve driven it like this for at least 40k miles so far... with no intention of pulling the turbo until Im ready for a full rebuild (which I already have on the shelf). I’m only needing to top up monthly with is far from a hassle, at this point. Hasn’t gotten any worse.
      03-25-2024, 07:43 PM   #4
reijimaho
Thank you, I will go to the shop later.
Thank you, How did you know that your turbo seal was leaked?
