12-07-2019, 11:07 PM | #1 |
Rep 49
Drives: BMW 340i
Same Parts ? Different Part # ?
Engine Cooling Radiator . Are these the same part but different part numbers ?
1711762805 171176600697
Bad40
12-07-2019, 11:43 PM | #2 | |
Rep 10,473
All BMW Parts are 11 numbers (or 7 dropping the first 4 which refer to general part of car they fit). Assume the second number is really 17117600697 |
12-07-2019, 11:48 PM | #3 | |
Rep 49
Drives: BMW 340i
So your saying . Any bmw part that starts with the same 4 numbers will fit ?
Bad40
12-07-2019, 11:50 PM | #4 | ||
Rep 10,473
I said anything starting with a 1711 is something to do with a radiator on some model BMW. |
12-07-2019, 11:52 PM | #5 | |||
Rep 49
Drives: BMW 340i
Bad40
12-07-2019, 11:53 PM | #6 | ||||
Rep 10,473
12-08-2019, 03:27 AM | #7 | |||||
Rep 49
Drives: BMW 340i
Bad40
12-08-2019, 09:29 AM | #8 | ||||||
Rep 10,473
https://www.realoem.com/bmw/enUS/sho...11#17117628057 https://www.realoem.com/bmw/enUS/sho...11#17118625447 Just because the same drawing is used does not mean they are identical Realoem and others use generic drawings. There is clearly a difference, whatever that difference is or BMW would not have 2 different parts numbers. That said, it does not mean 100% that the other cannot be used. For example, in a different thread the differences in the MSport and M4 steering wheel are discussed, even though the actual parts can be swapped between the 2. |
12-09-2019, 03:41 PM | #9 | |||||||
Rep 49
Drives: BMW 340i
Bad40
