BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Diamond Cut Wheel Repair DIY
      10-23-2018, 04:34 PM   #45
davethefish
davethefish's Avatar
Drives: 2012 F30 320i Sport
Originally Posted by teaston View Post
My clear coat was fine, which one did you use? I used this stuff:
Auto Inpart Clear Gloss E-TECH Alloy Wheel Lacquer Chip resistant Wheel refurb https://www.amazon.co.uk/dp/B0079Z6M..._D44ZBb5F8SCH7
I used the wurth alloy wheel lacquer. to be fair it lasted about a year before it went white after de bonding.
https://www.amazon.co.uk/Wurth-Gloss.../dp/B001MPUH6O
but i'll give the other stuff a go this time round
might get a can of this Adhesion Promoter to test as well, see if it will help the lacquer to bond.
https://www.amazon.co.uk/Mipa-Adhesi...esion+Promoter
MOD's/DIY list
Bonnet Badge Repacement, LED Door Sills, 35%VLT Window Tinting, 442m alloys, Stainless Steel Pedals,
Front and Rear Disk Replacement, GTechniq C1 Detail, Gladen HIFI upgrade, LED DRL's, 90mm Stainless Tailpipe, Complete Leather Reupholstery.
      10-23-2018, 04:38 PM   #46
teaston
Drives: X3 M40d
might get a can of this to test as well, see if it will help the lacquer to bond.
I didn't have my wheels for a year after i refurbed them, they got replaced for corrosion around the centre caps.
      10-24-2018, 05:58 PM   #47
jamiem1987
Drives: BMW 335D LCI
Many thanks! I have the laquer ordered and will give it a go this weekend. I highly doubt i’ll get any where near your quality however as my curbing is fairly deep and goes round approx a quarter of the wheel
      10-25-2018, 04:56 PM   #48
jamiem1987
I have posted this on another thread but no one's looking at it so thought I'd give it a thread as I'm so impressed with the results! I will never get a diamond cut wheel refurbed again.
I used Halfords emery paper kit, first the medium grade and then the fine, always going in the same direction, then with 2000 wet and dry (dry) & finally 3000 grit wet and dry paper (wet). Then polished with Autosol metal polish, cleaned thoroughly with IPA & finally finished it with E-Tech alloy wheel lacquer.
Edit:
To get a better finish fine wet sand again after lacquer has fully heardened, then polish with paint cutting compound.
If you look closely you can see where the repaired area is a slightly different colour, but you would have to be looking for it.
Before and after:
free upload pictures
Teaston just wondering if you can tell me what exact grit you started wih? you mentioned medium but the paper kit I have is only labelled in grit numbers rather than sizes.
Also when you re lacquered the repaired bit with the ETECH stuff, how many passes did you do with the spray? I have the same lacquer arrived today, will be trying this on Saturday - my curbing is fairly deep i’m
just a bit worried about taking too much off to get down below the gouges but looking at yours, yours looks fairly deep too and I would be more than happy if mine turns out as good as yours so this gives me confidence!
Thank you
      10-25-2018, 05:16 PM   #49
teaston
Drives: X3 M40d
Thank you
Starting with 800 grit should be ok, although if the damage is deep you might need 400. Then finish with some 1500 or 2000 before cleaning thoroughly with alcohol.
I do 4 or 5 coats of lacquer around 15 mins between each other. Make sure the spray can is at least 17°C, and preferably the wheel and ambient temperature too. Then leave it at least 24 to 48 hours to dry, and don’t put any sealant or wax on it for at least a couple of weeks to allow all the fumes to escape.
      12-09-2018, 01:10 PM   #50
TQMp5135
Drives: BMW 435i F32 6MT (MPPK, MPE)
Excellent job! Thanks for the detailed guide too. I've managed to keep the 19's on my 435i pretty spotless until rolling into a high curb on a dark night a few weeks ago :-(. The damage is fairly noticeable so don't really want to leave it. I've ordered my stuff and am going to give this a go as soon as it arrives! Will post results!
teaston10993.50
      12-10-2018, 12:49 PM   #51
fuzzybunny
fuzzybunny's Avatar
Drives: Orange F33 435dx Convertible
Ive got a guy coming out next week to clean up my diamond alloys. He uses a manual technique just sanding down himself by hand, polishing and lacquer, takes about 90 mins per wheel. He take the wheel off and deflates the tyre before setting to work. I'll post results and cost in due course. He is employed as a contractor by my local BMW Yeovil so assume he is OK!
      12-10-2018, 01:01 PM   #52
teaston
Drives: X3 M40d
I'd be interested to see his results! No doubt better than mine, but if it's totally invisible i'll be shocked.
      12-10-2018, 01:27 PM   #53
Alice Coupe
Alice Coupe's Avatar
157
Drives: F36 430dX M Sport
The question isn’t really about how good it looks now, but what it will look like in a years time. Not many repairers will give a year warranty on diamond cut.
Love to be surprised though.
      12-10-2018, 01:30 PM   #54
teaston
Drives: X3 M40d
That’s the good thing about doing it yourself, if it goes milky you can just sand it again and give it a few more coats of lacquer.
      12-12-2018, 03:24 AM   #55
fuzzybunny
fuzzybunny's Avatar
I'll let you know, you've got me worried now! Your repair looks great so well done. The 'wheel specialist' in Weston gets good reviews but that's an hours drive away and I have to leave it with them so quite a faff, they remove the wheels and tyres then grind the surface, relacquer, rebalance etc. Cost for that is £250 for two wheels and I think there's a limit as to how many 'grinds' they can do. There is another service where they come to the house and take the wheels off and take them away, (leave the car on bricks and you never see them again! LOL).
So much easier to have someone come to the house and do it while I'm there as I work at home a lot. We shall see, I'm not expecting the perfect job that defies close inspection just want it to look good when standing next to it. Pictures will be posted in due course.
      12-12-2018, 03:52 AM   #56
Alice Coupe
157
If your car is in warranty, I'd just wait for the wheels to corrode and claim new ones.
      12-12-2018, 04:24 AM   #57
fuzzybunny
fuzzybunny's Avatar
You make it sound like an inevitability, hope you're wrong!
      12-12-2018, 04:56 AM   #58
TodmordenLad
Drives: Audi A4 Avant
I'm on my third car with diamond cuts and I've never had any corrosion on any of them
I'm on my 6th BMW and I've never had any problems with any of my wheels
That said, when the roads are bad - full of salt and crap during the winter months - I don't use the car much
EDIT: And i NEVER use the pressure hose anywhere near them
Owned: 440i GC LCI with MPPSK, F31 330D M Sport with MPPK, F11 530D SE, F11 520D SE, E61 530D M Sport, E36 325i plus many MB's, Audi's & Volvo's
      12-12-2018, 06:38 AM   #59
Alice Coupe
157
2.5 sets on a BMW in 3 years. 4 sets on a Kia in 6 years.
If I can avoid diamonds cut in future, I will. They are not fit for purpose.
      12-12-2018, 06:42 AM   #60
teaston
Drives: X3 M40d
Two of my 442M's have been replaced due to corrosion around the centre cap, and they're not on my car at all during winter!
      12-12-2018, 06:45 AM   #61
TodmordenLad
Blimey. The climate where you drive the most must have something to do with it. Plus use of a pressure washer on the wheels - which I avoid.
I've never had a problem :
      12-12-2018, 06:48 AM   #62
Alice Coupe
157
Who said anything about a pressure washer?
I only use soap and water to clean the wheels. Judging by the number of threads on this forum alone, it's a very very common problem and not limited to BMW.
      12-12-2018, 07:56 AM   #63
fuzzybunny
fuzzybunny's Avatar
Wow, now you've got me worried, got any pics of the kind of corrosion that happens on the centre is it around the wheel bolt holes?
      12-12-2018, 08:13 AM   #64
Alice Coupe
157
Plenty of threads here with pics.
      12-12-2018, 09:35 AM   #65
teaston
Drives: X3 M40d
Directly around the centre cap, like this:
      12-12-2018, 09:59 AM   #66
fuzzybunny
fuzzybunny's Avatar
Thanks for that teaston just had a look and I have got similar marks (dam!) so will take the car to my local dealer for inspection. I'm expecting to be fobbed off as I don't have the full car history, (apart from service history), but we shall see. I don't even like the diamond wheel appearance TBH but kind of stuck with them.
