BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > VERY Noisy Engine?
      10-04-2019, 01:58 AM   #23
Busted
England
91
Drives: F31 335d
Originally Posted by betty02 View Post
I don’t see how starting the car for 30 minutes is why it’s “shagged” I used to drive it from Blackpool to Leeds and back each day and never wanted to take it on the motorway stone cold. I don’t get what issue leaving the car ticking over will do? Say my journey was an extra 30 mins the car would be on for the same amount of time right?
Just seems strange that it was absolutely spot on when I parked it Wednesday night then this from the morning. Hopefully not a chain issue as that will be expensive I presume!
I will give the filter a check over at the weekend and drive the Mrs’s little corsa about for the time being
You're running it with cold oil for a lot longer as it will take longer to warm up. It will definitely increase internal wear which is why the manual tells you not to do it
Probably not why it sounds like that though, take it to a garage, as far away from any kwik fit as is humanly possible as let them have a look at it
      10-04-2019, 02:00 AM   #24
betty02
betty02's Avatar
Drives: 316D
Well that is new to me! F*** sake, worse when I thought I was actually doing a good thing!
I will double check the filter over the weekend and all that then I will get it to a local indie! Anyone know any good places near Wakefield/Leeds that wont kill me!
Well you live and learn I guess, really did think I was doing the right thing.
Just hoping it'snot chain as that will be very costly, shame as I was hoping to sell after winter
      10-04-2019, 03:08 AM   #25
Sasquartch
Drives: 520i G30
If it's the chain tensioner then you might be able to get it checked for free by BMW
My workmate with a 10 year old 123d had a new tensioner fitted free of charge so worth a call
I'll dig up the service bulletin
      10-04-2019, 03:26 AM   #26
betty02
betty02's Avatar
Drives: 316D
Sounds interesting! Think it maybe just a tensioner then? Rather than full thing?
      10-04-2019, 04:27 AM   #27
betty02
betty02's Avatar
Drives: 316D
Rang BMW UK (Found the above bulletin online) and he just said zero recalls for your car so nothing they can and will do.
      10-04-2019, 04:41 AM   #28
Sasquartch
Drives: 520i G30
Just for anyone interested attached is the bulletin from BMW regarding the chain tensioner
This refers to Exx cars so possibly it's different for Fxx cars although the engine is still the N47
      10-04-2019, 05:28 AM   #29
E60525d
E60525d's Avatar
Drives: 330d M Sport LCI
There was a later bulletin for F series car but only covered cars to around end of 2011 from memory.
      10-04-2019, 05:34 AM   #30
Hooded
England
1669
Drives: F30 330d M-Sport
Wills28647.00
      10-04-2019, 05:48 AM   #31
betty02
betty02's Avatar
Drives: 316D
That pretty much some it's up! This is a 63 so probably out of that as well. He literally just ran the reg seen no recalls and left it at that. Strastone and Sandal are not cheap. So may fine a specialist locally.
Kills me for getting a new car next year. Still hoping it maybe oil filter elated or something like that but having listened to a few YouTube videos... the tank noise isn't great!
£1600 seems an average price
      10-04-2019, 08:34 AM   #32
Kermit
Drives: 335d xDrive Shadow Edition
The notorious N47 tensioner problem doesn't make *your* noise (it's more metallic than induction/exhaust); nor does the issue relating to the recalls, let go as suddenly as yours has (it slowly gets worse, not, next morning it's broken). It does need looking at fairly urgently though I'd offer.
Have you changed fuels/fuel stations recently? Bad batch?
      10-04-2019, 08:52 AM   #33
HighlandPete
Drives: BMW F11 535i Touring
Originally Posted by xenon View Post
Letting an engine warm by idling is a very bad idea, it warms up so slowly that you get condensation everywhere internally. As has been said above - and as it says in the manual - start up and drive off immediately.
And more likely to have more carbon goo in the inlet tracts. Diesel takes forever, at idle, to warm up. Start up, a few seconds to get the oil around the engine, and get moving at sensible loads. Fastest way to heat the engine and run a 'dry' motor.
OP's issue, definitely investigate... particularly for timing chain issues. Not unknown (with new oil), to get more noise when there is a problem developing.
      10-04-2019, 09:30 AM   #34
betty02
betty02's Avatar
Drives: 316D
Yeah it did seem strange that it was fine one night then not the next. Spoke to a specialist and sent him the video and he said don't start it again going to go bang and then it will be double costs.
Still part of me that doesn't get the sudden change! I filled up a few days earlier, normal petrol station, but brimmed it more than normal
Oil developing or not, would this be a re-drain and change? He also said it sounds like it's running on 3 or 3.5 cylinders which I am not sure about as it;s never missed a beat before now engine wise!
      10-04-2019, 09:50 AM   #35
Sasquartch
Drives: 520i G30
I did think when watching your video that it wasnt running on all 4, there is a definite rocking to the engine which points to something out of balance
The best plan is to get it to a specialist asap, there's a limit to what can be diagnosed over the internet :-)
      10-05-2019, 07:09 AM   #36
Mister X
Mister X's Avatar
Drives: 2014 320d ED
Originally Posted by TaranF32 View Post
Not necessary but just feels like a good habit, make sure the various fluids get moving, especially on a cold winter morning. I usually start the car up, put on my Spotify playlist and check my messages/emails on my phone before setting off. By the time I've done that usually passed 4-5 minutes
It's a bad habit.
Best way to warm a car up is to start it and then drive it asap.
      10-05-2019, 09:57 AM   #37
seenthelight!
Drives: bmw 435d f32 coupe
hi mate, unsure what the problem is - could be a number of issues. take it to german autocare in wakefield, 01924 369898, monkton road industrial estate, just off denby dale road. highly recommended specialist and good prices.
as for warming up before setting off, your car just needs enough time for the diagnostics to check that all is ok and for any check lights to extinguish (and any new ones to activate if required) - 1 minute at most. modern engines are designed to warm up on the move and under moderate load - drive straight away, but don't give it the beans until up to temp (90-100 deg).
more importantly is the stopping/turning off procedure - when parked up and handbrake on, leave for 1/2 to 1 minute for all fluids to settle and for the turbo to 'spool down' and settle, and turn off.
fwiw, i am an angineer, so am a bit picky regarding my cars servicing and running/operating procedures ...
Ex S3 & GLA45 AMG ... now 435d F32 coupe
      10-06-2019, 05:16 AM   #38
betty02
betty02's Avatar
Drives: 316D
I looked at that place other day gave them a call Thursday and they didn’t come back to me there’s one not far from me in Wakefield! Might try get it there.
The Mrs has made me mega paranoid asking if I have put petrol in instead of diesel, I was convinced I hadn’t, but as I’ve driven her car a bit (petrol) it’s made me really paranoid!!
If I did it wouldn’t sound like that would it? There’s no way of checking is there? Brimmed full tank as well!
I thought the nozzle of a petrol pump wouldn’t fit in a diesel but it might be the other way around!
      10-06-2019, 05:34 AM   #39
betty02
betty02's Avatar
Drives: 316D
On the above put £70 in Monday and it ran fine Monday night, Tuesday day and night and Wednesday
      10-06-2019, 06:00 AM   #40
bishbosh
Drives: F30 335d
2014 BMW 335d  [0.00]
Correct, you can't normally fit a diesel pump nozzle into a petrol.
Running petrol through a diesel engine would knacker the high pressure fuel pump, eventually causing it to seize and the chain to snap. This is because petrol is a solvent and strips the lubrication from the fuel pump.
      10-06-2019, 06:47 AM   #41
betty02
betty02's Avatar
Drives: 316D
And mines a diesel! I don’t think I have! I doubt it would’ve run for a few days if I did!
      10-06-2019, 07:39 AM   #42
machman767
machman767's Avatar
Drives: 320i M Sport+
Perhaps take the filler cap off and have a sniff, should be able to tell fairly quickly I'd have thought?
      10-06-2019, 10:12 AM   #43
Eddamoo
Drives: BMW 430dX
Echo the comments above, that sounds like it's running on all 4 but badly as though it's been misfuelled. Could also have a glow plug issue. Have a good smell at the tank filler, you'll be able to smell petrol amongst the diesel.
Have you checked for codes?
      10-06-2019, 12:39 PM   #44
speedski
speedski's Avatar
547
Drives: Former F40/F36/E81/E85 Owner
What does the receipt say you put in?
