12-08-2019, 03:29 AM | #1 |
Rep 31
Grease for Brake Pads?
Just changed stock brakes for 328i and added a thin layer of grease to the back of the pads and where the piston meets the pad. I also added that same grey grease to the slide pins. Later I read that BMW recommends you do not do this. Should I take the pads off and clean the backsides? I noticed when I changed them the pads were bone dry anyway so I wonder if it matters that much?
Any input would be appreciated. First time doing a job like that and of course going to do some noob stuff |
12-08-2019, 08:32 AM | #2 |
Rep 16,081
Six out of twelve mechanics will tell you to grease the back of the pads, the other six will tell you not to grease them. I've greased mine for fifty years and it hasn't caused a problem so far. Greasing the contact points between the pads and carriers and the slide pins is the most important part.
johnung4528.00 |
12-08-2019, 11:17 AM | #4 |
Rep 387
I haven’t put any type of grease on the backs of my pads for years, and haven’t had issues with squeal or chatter. That said, I always use OEM parts, so I can’t say if that makes a difference or not. I do however always put a very thin layer of dielectric grease on the slide pins.
12-08-2019, 12:23 PM | #5 |
Rep 603
Rumors rumors...
The truth is, BMW recommends to apply Brake pad paste! https://www.newtis.info/tisv2/a/en/f...heel-brakes/1V However, use the right stuff and apply as recommended!
335i F31 RWD in SB || Powertrain: Active Autowerke Flash Tune Stage 1 | AA Charge Pipe | AA FMIC | GFB DV+ | xHD Trans-Flash | Quaife LSD | Cyba 3.5" Carbon tips || Chassis: 20" 405M | Wiechers Strut Bar | Rear M-Diffusor || Brakes: 18" M-Perf Brake orange 370/345 | EBC YellowStuff pads all around || Various: LED bulbs: Fog-L. front | Turn Signal f&r | Brake L. | Reverse L. | Rear L. | Rear Fog L.
12-08-2019, 07:25 PM | #6 | |
Rep 16,081
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Note the pictures. They put it on the back of the pads. |
12-13-2019, 01:57 PM | #7 |
Rep 975
BMW also recommended 15K oil change intervals and tells everyone the transmission fluid is "lifetime."
Keep in mind, BMW is here to make themselves money, not to help you save money. And yes, I always grease the contact points. It's really just common sense.
15' 435i F33 Metallic Grey/Dakota Black/Contrast Blue | AWD | M Sport
15' 328i F30 Mineral White/Dakota Saddle Brown | AWD | Luxury Line |
12-13-2019, 11:13 PM | #8 |
Rep 605
Go off what the parts manufacturers recommends, not the car brands. For example, transmission manufacturer that supplies BMWrecommends fluid changes every 60k or so...BMW/dealers says lifetime >.>
So yeah, like many said, grease the contact points. |
